swingarm chain slider
Discussion in '4 Stroke' started by demi, Feb 7, 2010.
  1. demi Husqvarna
    Cheyenne, WYO
    12 WR 300
    '14 SH 500, 81 Gilera 125 C1, 17 KTM
    08 TC 510....is there anything else besides OEM? I could not find one on TM Designworks site....please advise. Thanks.
  2. andyman Husqvarna
  3. dukepilot Viva l'Husqvarna d'Italia!
    Morgan Hill, CA
    450 SMR, TE250, CR125, SM610
    Duc, Buell, Honda
    If you are looking for the chain slider/rubbing block on top of the swingarm, UFO Plastics nmakes a chain slider. Not sure if it's as good or better than stock though. Maybe it will work good enough with this mod... http://motoman393.thumpertalk.com/tech/swingarm.html
  4. demi Husqvarna
    Cheyenne, WYO
    12 WR 300
    thanks Andyman. I have the BRP guide, I am looking for a swingarm slider, near the pivot. I thought TM had them, but couldn't find it on their site. Ah, I will check the UFO slider out. thanks Duke.
  5. andyman Husqvarna
    Awwww dangit! :banghead: Dunno what I was thinking. Yeah, far as I know, TM doesn't make one for us. Sorry 'bout that.
  6. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    be advised a slider with a higher hump is in the works helps neutralize acceleration squat/compression. ZipTy is in R&D
  7. Doormandan Husqvarna
    So Cal
    1+ on the BRP my 06 TE250 had one. I removed it when I sold it and installed it on my 08 TE610 no issues.
    Dan L:thumbsup:
  8. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    2 Ducs, 14 GG 200, 13 Husa 300
    I need a new solution for this too. I've blown through three stock ones and 1 aftermarket (UFO). I even tried going to a larger front and rear sprocket to *see* if that might make a bit of difference. I thought I remember a post somewhere saying a KTM slider will work. So I'm just bumping this thread up hoping that maybe a new idea is out there, as I am on the market for yet ANOTHER chain slider. :P
    Incidentally, the UFO is poorly designed and doesn't even cover all the swingarm area that the chain could make contact with. With this aftermarket one, the chain actually caught the side of the slider and ripped the bolt out. Special!
    http://www.oemcycle.com/Item/product/1628/PU/1231-0150/HUSQVARNA_CR125_05-08
