125-200cc swingarm install help !!!
Discussion in '2 Stroke' started by troy deck, Mar 20, 2014.
  1. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    we just took off the swing arm and got new bushing and bearing moose kit (all balls) they are identical to the factory ones but the swing arm will not go back flush with the motor. anyone else have this problem. its like the fame shrank within the week. please help!
  2. Clete Husqvarna
    Tigard, OR
    '01 CR/WR 250, '13 650 Terra
    '06 Suzuki SV650 (gone)
    Hmmm, I seem to remember using an old bushing versus the new, because of difference in size.
    The only bearings I didn't have issues with were the wheel bearings, only becasue the old ones were fine.
    Headset bearings, I ended up trading back and forth with Bryon/BMP
  3. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Make sure the main bushings and the larger rings are both on the inside
    If that makes sense. So seal on outer then the two needle rollers the big ring
    then the bush that goes through the
    Lot.
    I may of gotten wires crossed but i assume this is the problem
  4. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    we do have the rings on the inside it seems like the brake side frame rail is pushed in about .060 and the frame rail on sprocket side has been pushed out about 4mm out. and both old and new bushing will not fit. and what are yalls thought on HMDP or 954 navy bronze bushings.
    willl post pics later for a better understands
  5. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    That would be good just thought it sounded like you had
    Put the bushes in from the outside pics are good:)
  6. msmith345 Husqvarna
    Shawnee, KS
    '12 WR250, '92 360, '80 390
    '72 Yamaha R5, '17 SV650
    Mine was tight when I put my 250 back in my frame. I assumed the 360 was slightly narrower and I had pinched the frame together a bit. My fix was to grind a very little amount off the end of the bushing (the small end that goes through the swing arm) as it was catching on the frame. Not ideal, but it did the trick for me.
  7. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    yep we didnt take it apart but that what we did who'd thunk they both go on the inside all fixed now thanks
  8. Treesmacker Husqvarna
    2010 CR150 "Woods set-up"
    YZ125
    I did the same thing once, the Husky seems to opposite of any other bike regarding this.
  9. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    good now i dont feel like such a retard with a wood burnin computer:confused:
  10. Freaky Husqvarna
    Kidderminster Worcestershire UK
    2010 TE250 x-lite Race ECU/Injector
    You're not alone, I did this too. It's a man thing, we refuse to read instructions!
  11. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    He shoots... He scores whooo i knew if i kept posting
    Oneday i would be right woooo.
    Glad i could be of service
    Freaky likes this.
