125-200cc Swingarm spacer direction on WR125 2012
Discussion in '2 Stroke' started by stakesy, Jun 22, 2015.
  1. stakesy Husqvarna
    2012 WR125
    Honda XR400
    Fitting new bearings to swingarm on a 2012 wr125.
    Is the parts fiche correct that all 4 spacers go in from the inside or is that a mistake and the larger bore spacers are fitted to the outside and the longer from the inside? Seem a bit random if the fiche is correct?
    Handbook is useless as it doesn't show swingarm out.
  2. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Hmmmm-- All I can remember is the long item is on the inner side so would think the other go outboard , Just one of those things where you put it back together as it came apart so im a little stumped but for sure the long one is inboard
  3. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    they both go in from the inside like the 250/300s im pretty sure. yup random. ran mine like you said you were thinking about(as had bike apart fro months & forgt) but then changed em back as it can damage swingarm or something i believe. search on here think i posted asking the same question for the big bore bikes. common sense would say one in from inside one in from outside to seal the bearings but they have a rubber seal on outside. the swingarm is a very tight fit(must be dead square & tap it in) with both in from inside & much easier to get in if on opposite sides. someone correct me if im wrong here
  4. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
  5. stakesy Husqvarna
    2012 WR125
    Honda XR400
    Thanks for the replies. You are correct. I tried it with the short spacers on the outside and it was very tight when the bolt was torqued up. The swingarm became stiff and wouldn't rise and fall. I've now fitted with all spacers as per the parts fiche and it moves effortlessly. I have made a modification though as the simple o ring seems a bit undersealed. I have pushed the outer bearings in 4mm outerand fitted a pair of 28 x 22 x 4mm rotary seals to prevent water ingress when cleaning. It now has double lip seals and an oring. £5.00 for both seals. Can't hurt.
    Miezie666 likes this.
  6. stakesy Husqvarna
    2012 WR125
    Honda XR400
  7. stakesy Husqvarna
    2012 WR125
    Honda XR400
  8. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    good stuff i chucked an extra oring in mine to help(probably wont do much but wont hurt)
