125-200cc Switching from BR9EG to BR8ES??
Discussion in '2 Stroke' started by Yellowfin, Mar 4, 2015.
  1. Yellowfin Husqvarna
    Ocean City, NJ
    '13 WR144
    kdx220 (sold)
    So I have been having a lot of issues with my wr144 loading up really bad. I have been running a 36mm lectron. Running 40:1 Motorex
    Bike runs ok its just loads up the second I let off the throttle.
    Today I put in a br8es that I had left over from my kdx and it seemed to run much crisper with less loading up.
    Is it safe to run the hotter plug??
    I ride mostly trails in the mid rpm range
  2. KXcam22 Husqvarna
    Kamloops, BC, Canada
    2011 SM630, 2017 300XC
    08FZR6;07CRF450;98CBR900RR;02KTM200
    I would also suggest using the iridium BR8EIX. The iridium tip burns cleaner plus you often get a noticeable performance increase. I have them in every engine I own. Also might want to check your jetting as it sounds like it is running super rich somewhere. Cam.
    Motosportz likes this.
  3. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    What octane rating is your fuel? I would steer clear of hotter plugs and chase jetting buuut it may be what the engine wants, need some fellow 144 lectroners to chip in on plug ratings.
  4. Idacurt Husqvarna
    hailey,ID
    07 WB177
    Scorpa 175
    I would keep the plug and change your oil to one with a lower flash point.The Motorex looks pretty high.
    Amsoil Interceptor - 183 F
    Amsoil Dominator - 194 F
    Amsoil Saber Pro - 237 F
    Maxima Formula K2 - 240 F
    Maxima Super M - 280 F
    Maxima Super M Injector - 220 F
    Maxima Castor 927 - 420 F
    Maxima Bio 2T - 180 F
    Motul 710 - 190 F
    Motul 800 Offroad - 485 F
    Motul Bio 2T - 255 F
    Motorex Cross Power 2T - 230 F
    Lucas Semi Synthetic - 182 F
    Bel Ray H1R - 435 F
    Bel Ray MC1 - 208 F
    Bel Ray Si7 - 194 F
    Castrol Power RS TTS - 163 F
    Castrol 2T - 194 F
    wait4me, lankydoug and steadydirt like this.
  5. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    do you know what rod is in your lectron? have you tried leaning the rod? it should not be loading up so quick...maybe after 10 minutes of gnarly tight stuff but not as soon as you let off the throttle. i run castor based oil (which is considered dirty with high flashpoint) as do some friends and we idle out bikes for up to a minute and ride lots of tight trails mixed in with wide open stuff and rarely encounter "loading up"..a friend and i both run klotz supertechniplate which has a flash point of 460 degrees! no spooge with proper jetting...this is on older huskies and also a 95 360 with a lectron, all 40:1
    i will echo the above sentiment that a heat range change is masking another issue
    johnnyboy likes this.
  6. Yellowfin Husqvarna
    Ocean City, NJ
    '13 WR144
    kdx220 (sold)
    I have the ms3 rod, I have the power jet open only 1/4 turn (anymore then that and it gets wayy to rich) I have the rod about 1 full turn leaner then the starting point the guys at lectron gave me
  7. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I run Motorex at 50:1 in my WR 125 (stock TMX). No problems at all. Don't use an S plug. That's the only type that I have ever fouled (in my WR300). I like the Iridium plug for both my WRs, and have had good luck with the stock heat ranges. I also use the world famous, cruddy California ethanol pump gas.:rolleyes:
  8. justintendo klotz super techniplate junkie
    have you tried going leaner on the rod? i wouldnt get too hung up on straying from their suggestion, my 360 had to go about 2 turns richer to get good bottom end with no hanging idle. you will know when it gets too lean as the idle will hang and it wont return to idle as quick as it should..it does seem weird the pj is almost shut..
    i take it your filter is clean and not over oiled?
  9. Yellowfin Husqvarna
    Ocean City, NJ
    '13 WR144
    kdx220 (sold)
    Filter is good, I have had this problem since I got bike. With power jet open it spits raw fuel out of exhaust
  10. steadydirt Husqvarna
    Ontario
    2007 2002 wr 250 1994 wxe 250
    I use a hotter plug in cooler weather. Rode today in 20degrees F. Still spoogy.
    You need to rejet but the hotter plug is a bandaid.
  11. Oldscool Husqvarna
    South Australia
    None
    RM125, SWM RS500R & Superdual
    I haven't had anything to do with the lectron carb. Could a leaking needle and seat or float level set too high cause this issue??
    Perhaps low compression??
  12. justintendo klotz super techniplate junkie
    float level can, yes, but that should be easy to verify on lectron as they have a clear float bowl and even include hash lines to show where fuel level should be..the power jet only works in the top 1/2 or top 1/3 of throttle, depending on how carb is set up
  13. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    Checking compression is a nice thing to do
    My bike was fouling /eating plugs until I did a piston job and it all disappeared completely.
    Robert-Jan
    jmetteer and justintendo like this.
  14. Yellowfin Husqvarna
    Ocean City, NJ
    '13 WR144
    kdx220 (sold)
    My question really is will a hotter plug hurt the bike?
    ray_ray likes this.
  15. lankydoug Husqvarna
    MO
    WR
    TM 300en
    not likely going from an 9 to an 8. I would not run a 7 if I were you. I've been running an 8 on my WR250 and my YZ125 for years because it performs better especially when riding tight single-track it's less likely to load up and cleans out quicker when you get on the pipe.
    ohmygewd likes this.
  16. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Some pistons and chambers respond badly to hotter plugs if the plugs hot and your lean you risk holing a piston, if you run rich not just more oil but fuel as thats the cooling during combustion i wouldnt worry too much but i worry alot more than others.
    Huskys have fat domed pistons and are well made you may see hot spot under the piston when you dismantle in future... If your plug is like ash white and almost crumbly your far far in the danger zone.
  17. justintendo klotz super techniplate junkie
    plug heat range is not why the bike is loading up.
    johnnyboy and ohmygewd like this.
  18. mark1 Guest
    my wre125 did this and it turned out to be my float needle
  19. Yellowfin Husqvarna
    Ocean City, NJ
    '13 WR144
    kdx220 (sold)
    Thanks I will look at it afyet the weekend
  20. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Has the ignition moved could be too far retarded and the plugs helping rectify the issue
