I'm buying left over 2020 SuperDual and I had question or two. Owners manual shows a power supply behind the headlight cover but gives no details on what type of connector you can use to plug into it. I am sure I could cut it and replace it with something else but was curious if anyone knew what the original plug type is. Also, I want to run soft bags on this bike but the original pannier rack is no longer available. Anyone got one or know of a source?
The power supply connector can be either a water proof connector or a simple twin core white plug. There are only 2 spare connectors and one is a single core used for the OBD 12v. Don’t use that one.
