Syringes for clutch/ brake bleeding
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by 268fords, Apr 9, 2013.
  1. 268fords Husqvarna
    Powell, Wyoming
    08' TE510'
    So my wife works at a hospital and she asked me if I wanted some syringes that have expired and where to be thrown away. She brought me these catheter tipped ones. The tip is the perfect size for both bleed nipples on the clutch and brakes. I just safety wire the hose to the syringe. The size is perfect to where you don't need to keep filling it up. If you are flushing your brakes, these are awesome. I don't know how often hospitals discard these, but there shelf life is limited. My wife does home visits through the hospital and most are elderly so they had these kind. Just wanted to share my new found alternative to the turkey baster
    Harbinger and Coffee like this.
  2. ghte Husqvarna
    Bright, Victoria Australia
    My Bride does the same as well as hand wipes and rubber sergical gloves. The gloves are great and do not look ready fro disposal to me.
  3. duggoey Husqvarna
    NSW, Australia
    2010 TE 310
    KTM 690, Yamaha WR200, FGS650(800cc)
    You can buy them from the chemist/"drug stores" also.
  4. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    Also, Tractor Supply and vet supply places, for use with horses:
  5. KXcam22 Husqvarna
    Kamloops, BC, Canada
    2011 SM630, 2017 300XC
    08FZR6;07CRF450;98CBR900RR;02KTM200
    Keep in mind that some brake fluid causes the syringe piston to swell. Mineral oil is fine but the other stuff causes issues after an hour or so. Cam.
  6. 268fords Husqvarna
    Powell, Wyoming
    08' TE510'
    I have noticed that certain fluids have caused the plunger to swell, but with as many as she got me, I can open another one. She probably got me about 30 or so
  7. Coffee CH Owner
    The 60mL are the ones I like for pushing brake fluid up from the brake caliper... I found some at 'Ace Hardware', although availability would probably vary by geographical location.
    Harbinger likes this.
  8. Harbinger Hróðvitnir
    Tromsø, Norway
    2013 Nuda 900 R
    Buell
    I use this.
  9. 268fords Husqvarna
    Powell, Wyoming
    08' TE510'
  10. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    Shock oil does as well.
