"Tank gripper" - fairing protection
Discussion in 'TR650' started by Geeza, Dec 12, 2014.
  1. Geeza Husqvarna
    Sale, Victoria, Australia
    I have been pondering options on how to protect the plastic fairings and also add some tank gripper.
    One option I am trying is 3mm neoprene rubber with a self adhesive backing.
    Made up a paper template to get an idea of what shape I wanted then cut out the rubber with a bit extra on the top and bottom edges so it could be trimmed after fitting.
    Cleaned the panels down with some isopropyl alcohol then stuck the rubber on.
    As this is only 3mm thick I was able to wrap the rubber around to the back of the panel on both the top and bottom edge. This will allow the top edge of the rubber to sit between the panel and seat which should stop the edges from rolling back when I sit on the bike. This went on easier than I thought it would, got a couple of bubbles initially which I used a pin to burst and then smooth out.
    The bike is in bits having a few mods done but have temporary placed the panel on to give a rough idea of the finished product.
    Panels back on.
  2. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Ohh i like was watching some on the bay was dotted with raised clear bits to grip tempted but $$ image.jpg
  3. Geeza Husqvarna
    Yes that stuff is expensive, this only cost me $5 for a large sheet, have enough left over to make a few more if these get tatty.
    Went for a ride this afternoon, definite improvement on the polished plastic, feel more "attached" to the bike. Money well spent. :D
    juicypips likes this.
  4. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Looks very tidy too good job i like it.
    Moff69 likes this.
  5. drzcharlie Husqvarna
    Geeza, that bike is way too clean. Go get it muddy man...
    Moff69 and Geeza like this.
  6. Clete Husqvarna
    Tigard, OR
    '01 CR/WR 250, '13 650 Terra
    '06 Suzuki SV650 (gone)
    can you provide a link for the stuff you used Geeza?
  7. Geeza Husqvarna
    Hi, brought the stuff from a local foam and rubber distributor, it is listed as neoprene sheet 3mm self adhesive.
    Sorry I can't help more than that :(
  8. Clete Husqvarna
    Tigard, OR
    No that's great, thanks man!
  9. glitch_oz Husqvarna
    AUS
    Strada
    Looking good.
    That's Clarke's Rubber you got the stuff from?
    Noticed some "blinding/dulling" after only the first 200k's of dirt....for a few bux it'd be worth the effort, I think.
  10. silverstreakNZ Husqvarna
    Christchurch nz
    82cr500,76gp360,90wr250,81 420AXC
    74 tm400 , 02 gasgas ec 300
    god dam that electronic thing with its rain cover looks shit on the right of the engine . what sort of company lets nigel no thought position it there
  11. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Thats a regulator by the looks of it, no reason why you cant relocate it
  12. nev.. Terrarist
    Greensborough, Australia
    '13 TR650 Terra
    '14 XT1200ZE
    IF you relocate the regulator, you can position the plastic cover in the bolt holes where that was, and what you end up with is the original BMW part in the place that BMW intended.
  13. Geeza Husqvarna
    Feedback on neoprene rubber tank gripper I fitted a few weeks ago.
    The rubber is staying stuck so the adhesive is working very well and is not showing any signs of wear or moving.
    Big improvement on shiny panels, especially under braking and hard cornering.
  14. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Ace will have to stick some on my enduro ride just where to hide it on yellow and blue plastics....
