Tanks options for 08-09 models your feedback req.
Discussion in '4 Stroke' started by Sandgroper, Dec 15, 2009.
  1. Sandgroper Husqvarna
    Dubai
    Im considering producing my own subject to public demand and setup costs which I am currently investigating.
    Let me know the capacity you would prefer and if the standard design used on other bikes with saddle style tanks such as on the Honda 450X IMS tank is suitable for you. This design may cause the engine to run a few degrees hotter as it is more enclosed than the current 3 gallon option.
    Currently I think the tank option for the 09 range is pathetic and even more so the design they have gone with.
    Name the model/year of your bike as well
  2. NumberCruncher Husqvarna
    Wa State
    I think the biggest demand is for the 2008, 2009 and 2010 bikes with the puny 1.9 gallon tank. Most people would be happy with a 3.0 gallon tank give or take. If the shrouds fit, a steering damper fits then that should make about everyone happy.
    NC
  3. fitness2go Husqvarna
    Seattle WA
    Weight carried lower.
  4. HUSQVNA Husqvarna
    Arizona
    I'd settle for 2.5 to 3.0 on my 2009 TE310. That'll give me at minimum 60 miles. I second the steering damper & shrouds. I'll be first on the list when that exists!
  5. Motosportz CH Sponsor
    Yep, put all the gas below the stock tank. Make sure you cover EFI bikes and remember you can put the pump low as you can. My 94 WXC250 has a brilliant tank, slim and holds 3.4 gallons all doewn low and around the motor.
    BTW the EFI 610 guys need a solution really bad as well. Someone is going to own this market some day (I hope!!!)
    this is the single biggest reason husky does not sell bikes in bigger numbers. We are willing to pay a reasonable price for this and they completely ignore us.
  6. fitness2go Husqvarna
    Seattle WA
    KTM makes a killing off of in-house after market parts catalog!
  7. Motosportz CH Sponsor
    I would trade the flip flops, key rings, toasters and ipod covers for tanks
  8. fitness2go Husqvarna
    Seattle WA
    That's my point...they have all that and multiple tank options!
  9. I8AKTM Husqvarna
    Ipod covers??!?
    Ooooh......Where?:D
  10. I8AKTM Husqvarna
    Back on topic-
    I'd like a 3 gallon, weight low and tight, my TXC runs plenty cool now.
    I'm not worried about damper mounts- don't feel the need for one, but I do want to utilize the stock red shrouds.
  11. Shane Husqvarna
    Reading, Pa
    I culd also use a 3gallon + tank, 40 miles to a tank isn't cutting it! I can barely make it to school, haha
  12. PALMER84ONE Husqvarna
    Silverado, CA.
    08 TE450 THE ROCKET
    12 RS520, CRF150F/230F, YZ250
    LARGER tank for the FI 610 that uses stock shroud.
    LARGER than 3.0 gl. for the FI 510 down and carried Low and Damper compatable.
  13. KDXfile Husqvarna
    Alabama
    The stock 1.9 is fine for Enduros and Vintage MX stuff but I'd like a 2.5-3 for Harescrambles and cross country races.
  14. Wadman Husqvarna
    south carolina
    3.0 gal is plenty. But we must be able to use the stock shrouds.
  15. bajahusky Husqvarna
    jackson, wy.
    2008 TE 450:
    seeing as there is a 3 gallon tank available, though it is not perfect, it would be nice to see a 5 gallon tank for longer trips like Baja:D
  16. HUSQVNA Husqvarna
    Arizona
    Well... I'd just like to not have to be peddling gas from my buddies on their stock orange bikes on any given weekend I don't strap an extra gallon of fuel to my back. Gas isn't cheap when your in the middle of nowhere! An extra 1/2 gallon or more would go a long way to solve that problem!
  17. RedRims Husqvarna
    NY
    For me the ideal tank would be;
    -retain stock shrouds
    -2.5 -2.75 gallons
    -retain stock looks of bike as much as possible (read as - make it attractive)
    Maybe make two tank options;
    A 2.5 gallon tank for those of us who just need a bit more fuel capacity
    And a 3 gallon tank for those who need alot more capacity
    The beauty of the 2.5-2.75 gallon tank is that it could probably retain the stock looks quite well while affording the extra capacity.
  18. jaked308 Husqvarna
    South Bristol, NY
    2013 TE511, 2012 TC250, 2002 WR250
    2009 KLX250sf, 2005 TTR125LE (wifes)
    I agree with RedRims post. Making two tank size options would be ideal, but I'd settle for one tank that was 2.75-3 gallons. Please keep the weight low, do not make added capacity in the shrouds, and use the stock shrouds.
  19. noairkerr Husqvarna
    Colton Oregon
    2009 WR 125
    2006 yamaha wr250f 2005 ktm 200 exc
    The dream tank
    My ideal tank: 3 + gal. keep it slim put the fuel around the engine,you could drive a bus through the gap on stock tank.
    I have an old '05 WR-250f with a IMS lowrider "wraparound" tank that requires fuel ports on both sides with crossover,and fuel line to go around carb to create siphon as it is lower than float bowl (which it wouldn't on EFI)
    At first I was worried about sparkplug access,during a race or ride. But have never had to swap a plug all these years ,other than during standard maintanance .And if only putting a couple gallons in,all the weight is below the seat.
    Build that tank for the Husky and they will come ! Waiting with CC drawn .Kerry
    P.S.- don't forget to leave room for the steering damper post, and mounts for radiator covers
  20. huskyte310 Husqvarna
    Westchester New York
    09/te310
    I agree with redrims too. 2.5-2.75 is ideal.We all want to use our stock tank shrouds.
