TE/TC TC 2015+ fork guards
Discussion in '2st' started by taps, Jan 14, 2018.
  1. taps Husqvarna
    TX
    '94 WXC360
    '15 RMZ450, '08 RM250, & '74 MX360
    This is all random, but hang with me.
    I saw the below pic listed as guards for a '15+ TC/FC, and I'm hoping some of my TC/FC owning friends can help me out. Are the bolts for those holes parallel? If so, how far apart are they? I would simply measure a buddy's bike, but the only guards I've noticed in the wild on friends' bikes are the same style as on my '08 250xc where the mounting bolts are not parallel and fit guards like shown in the 2nd pic.
    BTW, I'm searching these for a set of '06 45mm shivers
    The 45mm Marzocchi Shiver looks like this (pictured with a set from a '10 sms630 that would likely fit the ktm)
  2. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    '18 TC 125...AER 48mm fork. front holes are pretty parallel and roughly 37.5mm apart. not sure if this helps. 20180115_111226.jpg
    taps likes this.
  3. taps Husqvarna
    TX
    '94 WXC360
    Thanks. If that is center to center, then they are a no go. I don't have the measurement in front of me, but they are much less than that.
  4. pvduke Husqvarna
    ... on the gas...
    yeh that was C-t-C pretty much....poops! oh well....plan B.
    taps likes this.
  5. Teambowles Husqvarna
    NorCal
    19 FE501
    19 ktm 6 days excf 450 n excf 500
    Edit: oops thought it was for fc
    taps likes this.
  6. taps Husqvarna
    TX
    '94 WXC360
    I do believe those guards would also work if the TC/TE guards did. I think I'm stuck with the stockers.
  7. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    I've got all those fork and guard combo's in the shop. Happy to do a test fit. What is it that you want to do?
    taps likes this.
  8. taps Husqvarna
    TX
    '94 WXC360
    I guess I'm looking for options. I found the part number for stock black guards. I've also found stock blue guards. I have not found an option for yellow or white. Also looking for something currently used so I don't get screwed when another oem number is dropped. If it looks like a simple bracket would make something work, great. The full wrap guards like the white ones in my original post don't fit well enough that I'd want to make a bracket. The front part seems easily enough done, but the rear bolt locations don't seem in a good spot for much of anything.
    I guess pics of the guards like pvduke and teambowles posted on the shivers made like in my posting would be cool. TIA.
