Hi My 2002 TC 450 cuts out at high rpm usually going thru 3rd gear then picks up again until same conditions . It was first time on bike and bloody dangerous as nearly got run over , at front from the off. It has a Leo Vince X3 Silencer. Any suggestions Rgds Ray
Either fuel or fire. You are probably wide open throttle when this happens, right?. Is it a single misfire, or multiple misfires? If multiple misfires, do they sound regular, spaced eveny apart, or are they sporadic and happen irregularly?
Hi Good news stripped carb and refitted a few air leaks around rubber seals from engine and to air box ,now runs perfectly. Thanks for reply Cheers Ray
