TC/TXC number plate on TE?
Discussion in 'General (Main)' started by Finnie, Jun 27, 2010.
  1. Finnie Husqvarna
    Darwin, Australia
    Hi All,
    Has anyone successfully mounted a TC/TXC number plate in place of the headlight on a TE (in this case a 2009 TE 250)???
    Do they just bolt on with no mods, or is this going to be more painful than it is worth?
    Have been doing some of this....
    And would like to get rid of the headlight altogether.
    Cheers,
    Finnie
  2. rancher1 Husqvarna
    WA
    You will need the holder that goes under the lower triple clamp, the number plate, and the upper L bracket with a few fasteners. It is easy to bolt on.
  3. Finnie Husqvarna
    Darwin, Australia
    Thanks Rancher,
    Does the holder that goes under the lower triple clamp from the headlight fit, or do I need to order a separate one?
    Thanks again for the reply - will make my shopping much easier!
    Cheers,
    Finnie
  4. rancher1 Husqvarna
    WA
    The brackets are different.
  5. husky bom Husqvarna
    you will need all the brackets because it mounts were the speedo/dash is i have the race plate at home to and it is just to mutch crap to do as it sits lower than the te one and will expose your dash
  6. kashlak Husqvarna
    Maryland
    I bought a number plate for my 07 TE for the same reason. When mounting it it just didnt sit right with the TE's digital dash. Ended up just selling to a fellow Husky rider. Its personal preferance i guess,i didnt like the way it looked.
