FE/FC TDC on 15 fc250
Discussion in '4st' started by RussellFC250, Jul 10, 2016.
  1. RussellFC250 Husqvarna
    2015 Husqvarna FC 250
    Ok so I can't find anything on finding TDC or marks on cams and where to align it.. can anyone help... got 45 hrs and just wanna do a valve clearance check..
  2. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    you might look for a mark like this - on the cam gears they will go parallel with the valve cover gasket surface or look on an orange bike site
  3. AndrewS Husqvarna
    Niagara Region, Ontario, Canada
    2015 FE350s 2013 TE310R
    2009 TE250 (sold)
    Does the FC have the same TDC locating bolt that the FE350, and the 350 EXC-f have?
    If you're not familiar with it, there's a bolt in the crankcase that has a thick washer. With the bolt removed, you can look through the hole as you slowly cycle the engine, until you see a spot the tip of the bolt can stick into. Thread the bolt in so that it locks the crank. This is when the engine is at TDC.
    Just don't forget to put the washer back on when reinstalling the bolt after you're done your valve check! ;)
    The bolt and washer are part numbers 2 and 3 in this pic. If you have a parts PDF (or hard copy) for your FC, you should be able to check if the same exists for that bike.
  4. Weantright Husqvarna
    Burton, Oh
    2019 FX350 w/KYB Inserts
    2017 FE250 w/OC, 2016 XTrainer w/KYB
    Do you really need TDC for checking?? As long as the valves are close and in the rested state on the cam, you can take your measurement. It's only when re-shimming you need TDC.
