TE 250 2009 Intermittent Stall
Discussion in '4 Stroke' started by Eoin, Sep 15, 2020.
  1. Eoin Husqvarna
    Gainsborough
    TE630, TE250
    Africa Twin AS
    I am getting an intermittent stall on my TE250. Changing down the gears, if I pull in the clutch to drop a couple of gears for a junction, sometime the engine just dies off. Sometimes fine. Running smoothly, restarts immediately. Often, I just bump it back by letting out the clutch, then it's fine when I pull it back in again. Never seems to repeat immediately. Starts on the button, idles fine. I've upped the idle a bit to see if that makes a difference, no noticeable change. Bike is fitted with PU, set up with iBeat and runs nicely on the dyno with a smooth power curve. Any ideas?
  2. GrooveThang Husqvarna
    2008 TE
    Your injector might need to be cleaned. I try switching over to an iridium spark plug also.
