TE 250 Remove Oil Filter Screen (7)
Discussion in '4 Stroke' started by TTEBB, Nov 14, 2009.
  1. TTEBB Husqvarna
    California
    Hi All,
    I'm doing the first oil change on my '09 TE250. I can't seem to get the oil screen indicated as number "7" in the owners manual out of the engine case. Please let me know if there any tricks for removing this filter screen. The other two (5 and 6) came out easily.
    I'm changing the oil at 50 miles per the instructions from the dealer and what I've found on the web. Everything looks good. Just the expected fine debris in the oil filter and a particle or two in the filter screens I was able to remove.
  2. Coffee CH Owner
    If you are referring to the screen of small diameter behind a single allen head in the front on the left side - I use the longer bolts from the oil filter cover. Insert, twist slightly, pull gently.
  3. TTEBB Husqvarna
    California
    I'll have to try that trick with the bolt on my next oil change. It occurred to me that the O-ring may be holding it in place so I used a dental too to remove the O-ring and the filter came out easily after that.
  4. BentAero Husqvarna
    Asheville, NC
    You can also stick needle nose pliers into the hole, and instead of squeezing, pull the handles apart. Screen should come right out.
  5. ghte Husqvarna
    Bright, Victoria Australia
    Be careful reinserting otherwise you can crimp/compress the mesh. Make sure it is seated properly before reattaching the end cap.
  6. Droolsport Husqvarna
    Arizona
    I just pulled mine to clean it and had about 1/4qt of oil come out of the hole after draining the motor with the main drain plug. Whats the point of having 2 pre screens before the paper filter? I will pull the bolt to drain remaining oil with every oil change now.
  7. Coffee CH Owner
    Dunno... I believe some people don't even remove the main drain plug.
  8. Colo moto CH Sponsor
    La Jara, Colorado
    7602racing.com
    You mean like me? :busted: I just pull the 2 side plugs and lean the bike to the left. Pick it up again, rock it back and forth a few times, and lean her over again. I only bother pulling the main drain plug every now and then to check for metal pieces.
  9. EagleOne Husqvarna
    Tarzana California
    I just pulled my sump drain plug lots of small metal on it! :confused: 400 miles is this normal?
  10. Coffee CH Owner
    My bike had all sorts of things come out in it's first oil change, especially orange gasket sealant.
    Is it your first oil change?
  11. EagleOne Husqvarna
    Tarzana California
    well I got it with 400 miles put on it so not excactly sure , done all 3 filters, the allen bolt mesh filter looked a little crimped at the end?
  12. mikezx Husqvarna
    cali
    i used a tool that i had that is normaly used to pull the small springs off of rear drum brakes. its a small screw driver looking tool but has a hook at the end that goes to a point! it works perfect!
  13. gandalf Husqvarna
    South Jersey
    I do the same thing but check for metal pieces by sticking my finger in the back screen and feeling around.
  14. spakls Husqvarna
    Easton Pa. USA
    Just got my 2009 te 450 did my 1 st oil change and no sreens in the engine?
  15. alkrisma Husqvarna
    New England
    that's crazy, what did the dealer say?
  16. gandalf Husqvarna
    South Jersey
    09, was it your first oil change or the bike's first oil change? Meaning, did you get it new from a dealer or used?
  17. Slowpoke Husqvarna
    Southern Ontario
    +1:thumbsup:
