TE/TC TE 300 frame guards - tired of waiting
Discussion in '2st' started by hawaii-rider, Feb 8, 2015.
  1. hawaii-rider Husqvarna
    Graham Washington, Fort Moose
    2018 TC250, 2015 TE300
    04 CRF-270x, 95 CR500, 93 CR250 etc
    Aftermarket for inexpensive frame guards hasn't caught up with the new huskies
    So....
    Took some HDPE cutting board sheet from tap plastics
    Make a template
    Wrap, snug with zip ties, slow heat, tighten...repeat
    Done
    Form fit
    Holds tight with tabs cut in the backside and two zip ties
    Chemical resistant and it's cutting board material
  2. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    Good idea. Do you have any pics installed? I went through this last spring with my 501. I used the blue ones from the husky book and some black non slip film for the lower part above the pegs.
  3. hawaii-rider Husqvarna
    Motosportz and reveille like this.
  4. hawaii-rider Husqvarna
    Left side mounted
    I cut and laid down some clear number plate sheet on the frame as a buffer first on both sides
    Motosportz likes this.
  5. LandofMotards Moderator
    Colorado
    2014 TC250
    So you finally bought a bike?!?! :)
    Where did you end up going?
  6. hawaii-rider Husqvarna
    North of me, Skagit Powersports, honest no bs out of the store on 20 min with the bike.
    Setting it up now, grease all bearings, guards, Tubliss, springs etc- we all know the routine.
    HR
    Lincolnlock and LandofMotards like this.
