Te 310 2011 Crank Bearing Removal
Discussion in '4 Stroke' started by hahaman, May 3, 2020.
  1. hahaman Husqvarna
    1981 CR 250
    Hi there,
    I would like to request, how to remove the crank bearings of a TE 310 2011. The manual is stating to heat up the case to aprx. 125 degrees celsius ( 260 F ) and than to drive in the new bearings. No big deal so far. Guess the same temperature will work for disassembly but I miss info for the removal of the screws securing the bearing retaining plates. These screws are secured with Loctite 270 which is high-strength treadlocker. Will these screws break loose when the case is heatet to 260F ? At room temperature the screws won't loosen and I fear to destroy the allen/ torx heads.
    Any info would be a big help,
    Thanks Al
  2. Motorcycle Ron Husqvarna
    Texas
    2013 TE 310R
    2012 Can-Am Spyder
    The thread locker should break loose at that temp. Give the screws a good whack with a small hammer before you try to loosen them
    joedirt likes this.
  3. hahaman Husqvarna
    1981 CR 250
    Thanks for the info, i'll try this and report.
