TE 310 - Trigger wheel?
Discussion in '4 Stroke' started by Biscuits, Aug 20, 2019.
  1. Biscuits Husqvarna
    2013 TE310R
    2006 Harley Sportster 1200
    Hi, trying to find out if the 2013 TE310R has a trigger wheel or some other mechanism that the crankshaft position sensor (CPS) uses for determining crank position. Whatever the mechanism is, I need to find out how many teeth are on it. I can't find this information anywhere.
    Thanks for taking a look
  2. Biscuits Husqvarna
    2013 TE310R
    Ok I figured it out. The rotor (8000H7695) has 18 teeth or keys on it that the crankshaft position sensor uses to read on the crank position. The parts fiche does not show the teeth, but if you remove the stator cover you will see them.
