TE 350 starting problem
Discussion in 'Older Single cams' started by Sarge1974, Oct 3, 2013.
  1. Sarge1974 Husqvarna
    TE 350
    Hi, got a 95 TE 350, not had the bike long but finding it hard to start, starts 1st kick turn it off then won't start again !!! It's a bit of a strange one. You can start it and turn it straight off then won't go again so I'm not talking when it's hot, leave it a few hours starts 1st kick again.ive cleaned carb, new plug, just seeing if anyone else as come across a problem like this. Any help would be great
    Cheers Simon
  2. rancher1 Husqvarna
    WA
    The 95 models had poor grounds on the CDI located behind the headlight. There was a factory reccommended update to add a ground from the frame to the CDI ground to improve starting.
  3. Sarge1974 Husqvarna
    TE 350
    Ok thanks I will look at that
