Te 450 electronic problems.
Discussion in '4 Stroke' started by 00sci, May 6, 2010.
  1. 00sci Husqvarna
    Finland
    Hello! I was taking a ride yesterday and suddenly when giving it gas it acted like it wasn't getting enough fuel. So I stopped and when I was trying to start it with the e-starter the relay just clicked. I kick-started it and it still acted weird. Once before the relay has clicked when trying to start it with the e-start, that time the + pole on battery was not connected properly.
    Today it just clicked in the relay when i pressed the button that normally starts the fuel pump. Pump runs when giving it 12v, all the relays works, the killswitch/e-start switch on handlebar works,
    The bike is a 2008 te 450.
    Has someone had similar problems? Where should I start looking.
  2. JasonfromMN Husqvarna
    MN
    None right now :(
    2013 Yamaha FZ6R
    Im not fluent with the electronics on these bikes but, it sure sounds like battery strength or a battery grounding problem to me.
  3. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    Yea, from the description the connection was bad- then fixed- then sounded weak. The weak battery could be because it was not getting charged by the stator well due to the bad connection. I'd put on a charger and recheck all connections. Might be in good shape then.
