TE 450 info needed on a 2006 model
Discussion in '4 Stroke' started by oneal, Jan 20, 2010.
  1. oneal Husqvarna
    uk
    1999 wr 250 returned home.
    07 TE 450 2005 TE 450 1999 CR 125
    Hi guys has you or may not know im looking for a replacement of my husky two smoke. and ive found a 2006 TE 450 with low miles. Now is there anything i should keep an eye out for inparticular. Any info you can provide would great.
  2. ghte Husqvarna
    Bright, Victoria Australia
    I have an 06 TE 450 with 4000 kms (2400 miles) all bush. I have replaced front brake pads once, new fork seals at 2000 miles and the battery 6 months ago. I have also replaced the accelerator cables and a stick broke my decomp cable. Apart from tyres she has been absolutely reliable and cheap to run.
    It has had the valve clearances checked 3 times-all ok and still in spec.
    I have had no mechanical or operational issues with this bike.
    I run bark busters, rear disc guard, bash plate, heavier springs and heat shield. The bike is otherwise stock.
    I change the oil every 3 rides and the oil filter every 2 oil changes.
    The air filter is changed each ride if dusty and or when it looks in need (be on the early side).
    I also put a spot of synthetic 2 stroke oil into the fuel (100:1 ratio) to protect the valves and assist in top end/ ring and bore lubrication.
    I can only commend this bike as A1 for reliability and performance. That said the later ones are a little lighter and do handle a tad better. I will keep her for another year and update (hopefully to a 350 or 400). I have converted my brother who has been hard core KTM to a 310 and he is now a die hard Husky guy. These bikes are a bit unique, do it there own way but do it very well- if the machine you are contemplating has had a demonstrable service history and looks, sounds and rides well then do it if the price is right. Best of luck to you.
  3. Coffee CH Owner
    Everything seems dandy on my 2006 TE250 :thumbsup:
    I've not read any bad things about the 2006 TEs, lasts a long time. :cheers:
  4. oneal Husqvarna
    uk
    Thanks guys thats given me the push i needed to get in touch with the dealer today. The bikes up for £2500 with 2000 thousand miles on the clock. ill let you all know what happens.
