I have some trouble With iBeat on my 2010 TE 450 It is running lean and it wont Accept adjusting the co 1, 2 or 3 up even if i set the adjusting value to 1,2 or 5% i get a Message that say that that value is not in range, the settings was 97, 100, 100 and it only can be adjusted Down, i am now at 95,100,100 and i just can not get the values up again.. any tip in this case ? Juvkam
Hmm, looks like it is a Ibeat sofware issue, on my old computer i have the 2.0 Version i used on my 2009 SMR And that wont work om my 2010 TE to richen up the Co's.. Bummer that my New pc is a 64 bit Windows :/
Yes you will need iBeat v2.1, and a 32 bit windows operating system. If I may, I recommend you PM fellow CH member jtemple for the fix.
