Te 450 shift drum upgrade info?
Discussion in '4 Stroke' started by Blackbeard, Oct 10, 2016.
  1. Blackbeard Husqvarna
    Te450
    I know they make a tc steel shift drum. But they are only 5 speeds. Does anyone make a 6 speed te drum in steel. ?
  2. Teeszy Husqvarna
    Crescent City, California
    2006 SM510R , 2016 FE501S
  3. hammer Husqvarna
  4. Teeszy Husqvarna
    You may be right, I don't know what it should look like, I was just trying to be helpful.
    Trenchcoat85 likes this.
  5. Blackbeard Husqvarna
    Te450
    Thank you for looking Teeszy but unfortunately I'm looking for the cylindrical drum the forks ride in. Ours are aluminum and I know they make a steel version for the tc
  6. Blackbeard Husqvarna
    Te450
  7. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    well, if you buy that one- call Bill's directly (& save them some fees). but you might wanna call Bill's either way: Bill will probably be able to tell you what is what.
    good luck
  8. Blackbeard Husqvarna
    Te450
    Thank you, and yes I apologize what I meant by posting that link is that it is a steel shift drum but for a tc, I would like one just like that but for the 6 speed te, I don't know if they make one or if the later model red heads maybe came with a steel one that would work
  9. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    ...and that is why I said to call Bill's- he could probably tell you. He's a sponsor here.
    let us know what you find out.
  10. rancher1 Husqvarna
    WA
  11. rancher1 Husqvarna
    WA
    I believe I have a steel one.
  12. jverdijk Husqvarna
    510 smr 2008
    @blackbeard
    if a 2008 smr 510 shiftdrum is the same i know a good replacement/custom part for you.
    a local shop made a alu version but anodised it, so its lightweigt and also hard enough.
    i had a stock 2008 version but ruined it while racing.
    with the custom version so far no probs.
    contact me if interested
