TE-510 OEM chain manufacturer
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Runner, Jul 30, 2010.
  1. Runner Husqvarna
    Los Angeles, CA
    2006 TE510
    I went to buy a master link for my 510 from Renthal and was told that master links to 520 O-ring chains are non-interchangeable, and that I need to know which firm made the chain. Could this be BS? If not, maybe one of you wizards know which firm made the OEM chain, allowing me to get the correct link.
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I couldn't find any markings on the stock chain I had on my TE450 either (I had originally thought that it was a Regina), but it lasted 6000 miles. If you can take your stock master link in to the store with you, the people there could probably match it up to some brand that they have in stock.
  3. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    per Rick Ramsey's measurements- various brands and models have slightly different widths. But you may or may not see an issue-less the fact that the master may not allow to be clipped properly or kink if too narrow- tight.
  4. Runner Husqvarna
    Los Angeles, CA
    2006 TE510
    It turns out that the some chain manufacturers stamp their name on the side links. The problem is that not all the links get stamped. I ended up having to clean the grunge off five links before I found the manufacturer's name.
    For 2006, Husky used Regina and DID. Both replacement links are given unique part numbers in the dealer's stock book. My bike had a Regina chain, which my local dealer carried the master link for. Issue over.
    Thanks Dirtdame and HUSKYnXJnWI for the suggestions.
  5. Motosportz CH Sponsor
    True, not all 520 chains are the same and you do need the right one for yours.
  6. Runner Husqvarna
    Los Angeles, CA
    2006 TE510
    I'm going to remove the chain to completely clean it. What solvent should I use on it to clean it without damaging the o-rings? WD-40? Acetone?
  7. Motosportz CH Sponsor
    Just spoke with Mototsportz Mike about this...
    there were 2 chains used regina or CZ... good luck finding a ML for the CZ
  8. ghte Husqvarna
    Bright, Victoria Australia
    I use kerosine to clean my chain then wash it it warm soapy water, blow off the water and put on a chain lube. Some guys just use WD40 to stop surface rust. The thought being that the "O" ring chains are already lubed. I put mu link pin on the inside as it resits swiping the frame a tad more.
  9. Runner Husqvarna
    Los Angeles, CA
    2006 TE510
    Last night I cleaned it in Simple Green and soaked it in SAE 20W-50. It will get some chain lube before the next ride. The Simple Green worked well.
    Thanks all for the replies. QED.
  10. benwiggin2 Husqvarna
    Brea, CA
    2008Te510
    2008 HD Dyna
    Mine was a CZ.
