Does adjusting the pressure sensor offset the fuel map linearly also?
Does the JD tuner change the resistance at different points (Idle, low, mid, high, etc)? So, do I need to unplug the tuner and measure Vdc at sensors? Also, my bike has 2 TPS's. Why is that?.... Tweaking the TPS a tad is the easiest way to richen or lean the whole map. .....
Does adjusting the pressure sensor offset the fuel map linearly also? Yes but is difficult to aachieve and not really practical
My bike won't run for more than about 1 sec on the first cold start. I have a JD tuner and have the idle adjustment (blue/green) leaned all the way out to get to it running on the 2nd cold start (used to take 4 starts). Is this normal?
I'm not sure.
No a JD doesn't get a TPS input. like other tuners it varies the pulsewidth (length of time the injector stays "on"). It does so through some complicated algorithms I presume, with no TPS input.
I would look at the coolant temp sensor on the cylinder or head. It should measure 2.8-3.0 volts at 70degf. More if colder, voltage drops with temperature. A good way to evaluate it is to compare it to the Intake Air Temp sensor in the airbox or airboot. They should read the same on a cold motor. The JD won't affect this. It is possible that all is fine and other factors cause the starting characteristics. Especially if it seems to run fine when warmed up.
Also, my bike has 2 TPS's. Why is that?).
I've never seen that. One is likely the MAP or manifold absolute pressure sensor, or an IAC idle-air control valve. If it has two throttle-plates one in the middle and one at the air side, the airside is a secondary throttle valve controlled by a motor, and would have a TPS style sensor to varify it's position to the ECM which may be identicle to the TPS, the TPS is ALWAYS in line with the main butterfly throttleshaft.
)..... Tweak the tps A LITTLE in the SAME direction that the throttle shaft moves when you open the throttle. Does that make sense? Ride it, decide if it improved it, and go from there.
So it sounds like if you wanted to tweak your fuel delivery across the board (linearly), tweak the 1st Throttle Sensor on the main butterfly?
Correct. In thinking more about it I have heard of TPS reset procedure on these 449/511's that involves disconnectiong the battery etc. Not sure if it works, but if it does, it MAY undo your tweak and recalibrate the ECM to see the higher tweaked TPS voltage as the "new" closed-throttle base voltage and make your tweak null.
All the sensors have a painted mark from the factory that makes it easy to get back to the factory setting (maybe put there for idiots like me).
Cool. Yes they are also there to help us mechanics decide if a sensor has been tampered with from new, if the paint is broken it can indicate a need for attention. As you found, they can be installed improperly.
It also apparently has a MAP sensor. I'm thinking it is heavily guarded in the front of the throttle body, with a different style adjustor.
Yes Keihin often integrates it right on the throttle body, a neat setup. On these FI setups the MAP acts as a BARO sensor at startup, and tells the ECM what the ambient barometric value is, then it reverts to a Manifold Absolute Pressure sensor when the motor is running. So, if your ride takes you 4000 feet higher, it may be necessary to shut the bike down for a few seconds, then fire it back up to allow the map to give the ECM an updated BARO reading.
Note to self:. DONT TOUCH
Yes Solid advice and no need to touch it!!
For my cold starting issue, I'm going to try an Iridium plug first before I pull the sledge hammer out to fine tune now that I'm dangerous with more knowledge!
Good call, I've heard that it does help!
My bike won't run for more than about 1 sec on the first cold start. I have a JD tuner and have the idle adjustment (blue/green) leaned all the way out to get to it running on the 2nd cold start (used to take 4 starts). Is this normal?![]()
Mine (smr 511) is fuel injected and it takes between 2-4 starts cold in the morning I just always thought it was normalMy TE511 with uncorked exhaust and JD tuner always take three tries when cold in the morning. Did it when completely stock too. Does not bother me as i let it idle a good 2-4 minutes before riding off anyway. Many people say with EFI let it start and run for a good minute or two before touching the throttle at all. this lets the TPS and learning part start clean.
It is to set the TPS to the desired voltage output at idle which on your typical Keihin setup is .5v at idle with safe range of .4-.6v. Tweaking the TPS a tad is the easiest way to richen or lean the whole map. Making the ECM think the throttle plate is open a bit more than it really is, will cause richer delivery. IE setting it at .6vdc at idle will be richer than setting it at .4Vdc. Of course it is rare that a machine needs linear change across the board to make it run better esp when adding pipes etc. That is where the fuel tuners are usefull that separate the map into many pieces or at least low, mid, high.
