The gear lever on my TE 610 is slightly bended and it scratches the left eng cover.Can i remove it and bend it back strait or it will brake in pieces?.Im not sure of the alloy its made of...aluminium probably...Has anyone done something simular?
its not really 'bent' per se, as I understand. Uptite makes a little spacer that solves the problem, and tightens up the action to boot.
Agreed on the above. When I stopped by Uptite last Dec. 26th on the way to Baja, George fixed me up with a spacer behind the lever. It had previously been rubbing on the case, but now it clears just fine.
