Fairly new to the Husky 610. I've got a 2007 TE 610 carb bike, I've seen reference to 22KW and 39KW, what does that mean and how do I tell what I've got? Thanks in advance for any help on this.
In 2007 here in Europe there was a law accodrding to which, until a certain age and depending on your seniority as a licence holder, you were not allowed to ride motorcycles having a power greater than 25 KW and anyway a power to wheight ratio greater than .16 KW/Kg. The 610, with its official weight of 142.5 kg, was limited, in the restricted version, to 22 KW (22/142.5=.154). I'm not sure that power restricted versions were exported in the USA. For the EFI version there is a tab limiting the rotation of the butterfly valve of the throttle body and a specific ECU with its specific part number and a writing on its label. Unfortunately I don't know about the carbed version, sorry, but if you have a pdf version of the spare parts catalog you could search "22 kw" or something similar to check whether there are results: it could be a beginning.
