TE 630 Chain Adjustment
Discussion in '610/630' started by capt42104, May 14, 2011.
  1. capt42104 Husqvarna
    CenCal
    Hey all!
    I just got a TE 630, and need some advice.....How in the heck do you adjust the drive chain? On a center stand, on the ground, on the side stand? The sticker and the USB manual really suck! It says .47" slack and it appears to be mid measured way on the swing arm. This can be because there all these guides and rollers which get in the way. My LC4 is really simple, this isn't. Thanks for any input.
  2. grusomkis Husqvarna
    Norway
    On my 630 i adjust the chain so that i have a little slack when the swing arm is paralel to the ground.At that point you have the longest distance between the front and rear sprocket and this is where the chain is on the tightest point. I take a tie down strap and pull the bike down, and then adjust. The sticker on the bike and manual says 12mm gap between the swing arm and chain. But nothing about if this when the bike is loaded or not. I have tried to adjust the slack to 12 mm unloaded, but then it got tight as a piano string when the bike got loaded.
  3. capt42104 Husqvarna
    CenCal
    Thanks! I sorta did the dame but sat on it and reached down to see if it was tight. I like your idea. I am fising to put a bigger rear sprocket, so this will help. Thanks.
  4. capt42104 Husqvarna
    CenCal
    This message board doesnt let you edit.....i meant to say i sorta did the SAME thing. Anyways, thanks for the reply.
  5. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    You can edit your posts; there's an edit button right on the bottom of each post you make.
    I just edited this one twice. :D
  6. capt42104 Husqvarna
    CenCal
    Hillarious! I am a little ADD, so it will take me a few times to find the edit button!
