TE 630 No Start
Discussion in '610/630' started by Jonathan Nickel, Dec 22, 2018.
  1. Jonathan Nickel Husqvarna
    My bike failed to restart after briefly shutting it off after a long ride. It has a new battery that has been on a charger.
    I thought that it had a fuel problem because it would start briefly with starter fluid (although it didn't run enthusiastically) so I replaced the fuel pump, which didn't help.
    So I checked for spark (which, obviously, I should have done before changing the fuel pump) and it was present but seemed weak/yellow.
    Does the presence of even minimal spark rule out a bad crank position sensor?
    I will probably order a coil and cap and see if that fixes it. Does that sound reasonable?
  2. Jonathan Nickel Husqvarna
    Update:
    The wire from the coil wasn't pushed completely onto the plug cap. I pushed it all back together tightly and it runs like a champ.
    DYNOBOB, mcnut and Eoin like this.
  3. mcnut Husqvarna
    2011 TE630
    16 Beta RS500, DR650, Tiger 800, CBX
    Nice trouble shoot, glad it was cheap easy fix (except for the pump).
    Bruce
