TE Speedometer/ Speedo
Discussion in '4 Stroke' started by ridehusky, May 18, 2010.
  1. ridehusky Husqvarna
    Murrieta , SoCal
    My Speedometer quit on my 2007 TE 510. Is there anyone that can repair this part? Greg
    PM ridehusky@msn.com
  2. Slowpoke Husqvarna
    Southern Ontario
    Did the speedo itself quit, or is one of the sensor wires broken?
    The sensor wires can break inside the sheath, causing the speedo to quit working....
    Also, sometimes the speedo/computer can get moisture in it causing the display to quit. Once opened up & dried out, it may start working again.
    (both of these have happened to me)
  3. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Does your headlight still work? I recently had my meter quit working in the middle of a ride, only to find later that my low beam had burned out. Once I turned the switch to high beam, the meter worked again. I keep spare light bulbs on hand all the time now.:D Funny wiring there, for sure.:excuseme:
  4. ridehusky Husqvarna
    Murrieta , SoCal
    Thank you members for the speedy advise! The display is fragmented and the speedo has no lighting. I did disconnect the battery and tried the possibility that a reset would work, but no luck. My low beam is out and will try a new bulb today. Otherwise, I will continue to dig.
  5. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    Ive had two husKies as new and neither speedo told correct mileage I d get an aftermarket one
  6. ridehusky Husqvarna
    Murrieta , SoCal
    I took the speedo apart last night and a chip from the circuit board was found loose and broken inside.
  7. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
