TE to SM caliper relocation/rotor
Discussion in '610/630' started by gimpy, May 11, 2011.
  1. gimpy Husqvarna
    Lancaster, Pa
    Greetings all. I have been the proud owner of an 07 TE610 for about a half year now. I picked up a set of factory SM450 wheels that were missing the rotors. The fit to the bike is perfect, I got a factory rear TE610 rotor that works fine with the SM 450 rear wheel, my question is the front. I purchased a SM kit from EBC for the caliper relocation bracket and rotor, but it won't work, the bracket is not even close to what i need.
    What caliper reloction bracket have you all found works for this application? The rotor hub is about a MM or two larger than the hub of the bike, so the bolts will be doing all of the work, so I suppose the rotor I got from EBC is not correct either. The kit I got from EBC is a SM6184LD
    Thanks for your help
