TE250 -08 MANIFOLD INTAKE part 8000B0369
Discussion in '4 Stroke' started by turbo100, Apr 27, 2021.
  1. turbo100 Husqvarna
    Hello,
    I have experienced that the mainfold is not seated securely on the carburator and there is occasionally a leak between the cylinder head and carb and of course the bike is running really bad.
    I refitted the clamp but I feel something is not correct so do you guys think the mainfold is warned out or do you have any other tips or trix?
    When I refit it the bike runs perfectly until it loosense again so there are no leakage in the mainfold as such.
    They are expensive :(
    Any tips?
  2. Eoin Husqvarna
    Gainsborough
    TE630, TE250
    Africa Twin AS
    Isn't the 08 FI with a throttle body?
    On mine (09), it's a bit awkward to get the clamp to sit correctly so it's secure. Have you tried lossening the top rear sub-frame screws and removing the bottom screws? Then you can move things around to get them seated correctly.
  3. turbo100 Husqvarna
    Hello,
    You mean to kind of lift the back-frame to be able to reach better to fit the mainfold and clamp?
    No I have not done this but it sould like a great tip, will test later in the evening!
    Thanks!
  4. Eoin Husqvarna
    Gainsborough
    TE630, TE250
    Africa Twin AS
    Just try it and see, it lets you move things around a bit.
