TE/TC TE300 running voltage
Discussion in '2st' started by HuskyDave, Nov 14, 2017.
  1. HuskyDave Husqvarna
    Zelienople, PA
    2016 TE 300
    can anyone tell me what voltage i should be getting at the battery with the bike running? It's reading 12.5v idling but I feel it should be closer to 14. at 60hrs the starter is only working half the time. it turns over very slow. based on all my internet reading it appears to be a common problem. thanks in advance.
  2. PDL Husqvarna
    amarillo, texas
    2014 TE 300
    Honda Crf 450X, Ktm 625 SXC....
    HuskyDave, sorry I'm out of town. I will check when I get in and post up.
  3. HuskyDave Husqvarna
    Zelienople, PA
    2016 TE 300
    Thank you pdl. I appreciate it.
  4. PDL Husqvarna
    amarillo, texas
    2014 TE 300
    Sorry its was a 6 hour drive this morning. My 14' TE 300 shows 14.41 volts on the battery when running. 12.67 when sitting. I hope this helps. George
  5. HuskyDave Husqvarna
    Zelienople, PA
    2016 TE 300
    Tremendously. Thank you George. Have a nice Thanksgiving. Dave
  6. PDL Husqvarna
    amarillo, texas
    2014 TE 300
    No problem. Let us know what you find. That seems low,does the voltage increase with rpm's?
  7. HuskyDave Husqvarna
    Zelienople, PA
    2016 TE 300
    No, is steady regardless of throttle input. Will do, plan to mess with it the next day or so. I watched a video where the plug from the rectifier was mucked up and kept the running voltages at 12.5 like mine. Cleaned it up and jumped to 14.4. Hoping my fix it that simple.
    PDL likes this.
  8. PDL Husqvarna
    amarillo, texas
    2014 TE 300
    Sounds like that may be it!
  9. HuskyDave Husqvarna
    Zelienople, PA
    2016 TE 300
    I know this is old but kids and work kept me from it. The plug off the rectifier was fine but one of the terminals on the relay was corroded. I believe the red white stripped. Cleaned it up and running voltage is at 14.4. I have a 16 300. When I unplugged the relay a bunch of water ran out. I washed it a month ago. It's 20 here and a few kicks she fired up. After riding the e start seemed much better. Thanks again pdl.
  10. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    pull your stator cover and check your wires, we did mods to eliminate a chafe/squeezed output wires issue. this is a new engine machine yes? 2017+?
  11. robertaccio Husqvarna
    San Diego, Ca
  12. HuskyDave Husqvarna
    Zelienople, PA
    2016 TE 300
    For a 16 300 but I'm going to pull it apart this winter to verify all is well
  13. KXcam22 Husqvarna
    Kamloops, BC, Canada
    2011 SM630, 2017 300XC
    08FZR6;07CRF450;98CBR900RR;02KTM200
    This may be rare but on a different bike i had a bad fuse that had a 4v drop across it. Cam
