Te310 11 Plate Uk Based Electric Starter Issue
Discussion in '4 Stroke' started by ben hickson, Feb 14, 2019.
  1. ben hickson Husqvarna
    TE310
    The bike starts ok on second kick. Thing is I want it to work as my son wants to learn to ride and therefore would be easier.
    The starter trusts to spin but the solenoid just clicks . When I remove the unit from the bike it spins fine : I have cleaned the the starter too and fitted new battery
    Any suggestions. I will take plug out tomorrow see if it turns the motor. Arbhhhh
  2. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    I'd guess one or more of three issues:
    • low battery capacity, or questionable battery leads for example
    • too much valve clearance ('specially the left intake which activates the automatic decompressor ADC)
    • scored, gouged, or worn ring/worm gear interface (might be hard to see) causing high starter drivetrain drag
    good luck.
