TE310 2010 Race ECU
Discussion in 'EFI/carb' started by shilo020, Sep 1, 2014.
  1. shilo020 Husqvarna
    Redlands, CA
    TE310 2010
    When you change from regular to race ECU is this just plug and play or do I need to reset TPS and CO numbers. It is at 105,105,105 now. I posted this here on the EFI section and 4 stroke in case different people follow here. I know this is a blast from the past but I hope someone remembers. Thanks.
  2. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    Yes, reset TPS and adjust CO.
    I HAD George (Uptite Racing in Santa Ana) do the swap on my 2012 TE 310.
    You could call if you have a question....1 714 540-2920
  3. Alberto Husqvarna
    Costa Rica
    2011 TE250
    what are the side effects on the engine of having the normal ECU replaced with Race ECU? for example engine life reduced, etc?
  4. glangston Husqvarna
    2012 BETA 350 RS
    Richer mix, a little more effective advance curve.
    I don't see a negative
    Maybe lower mileage.
    Alberto likes this.
