TE310 2011: clutch plates replacement
Discussion in '4 Stroke' started by monak83, Aug 13, 2019.
  1. monak83 Husqvarna
    TE 310 2011
    Hi,
    this evening I will replace clutch plates on my TE310 2011, some questions
    1 - there is an order on plates?
    2 - there is a troward?
    3 - to pull the screws is required a torque wrench? (if I haven't?)
    4 - any particular suggestions?
    Thanks so much
    Marco
  2. R_Little Husqvarna
    NJ
    It is easy to do.
    The plates are available. I have a few sets.
    Just get a 10mm socket and wack it with your palm and they will come loose.
    Remember how they come out.
    Put oil on fibre plates before installing.
    Tighten with 10mm socket and wack with your palm to tighten to about 10-12nm.
    That's it.
    Trenchcoat85 likes this.
