TE310 2011 idle only
Discussion in 'EFI/carb' started by Moesgaard, Oct 28, 2013.
  1. Moesgaard Husqvarna
    Skaerbaek, Denmark
    TE310 2011
    Kawi kx250f '12, Montesa 4rt '05
    Hello husky friends
    I have just bought a TE310 2011 with 96 hours on it, went well for about 1/2 hour, then died out, drove a bit, died again. Engine rebuild by husky shop 2 hours ago, new fuel pump 1 hour ago. All work made for the former ovner.
    It starts right away on button and kick, and idles well. It will only rew to about 3000-4000 rpms, when I try to ride it, it pulls sligthly and dies. After 1 min. It starts again.
    The fuel pump, pumps out gas when primming and when engine is turned over. Pressure not messured
    It has bin opgraded to 12 hole nozzle, race ecu and full leo vinci pipe and muffler.
    Can fuel pressure be to low and if, what can it be?
    Can nozzle be clogged with dirt our water, and if, how do I clean it?
    Other things?
    Regards Peter
  2. AndrewS Husqvarna
    Niagara Region, Ontario, Canada
    2015 FE350s 2013 TE310R
    2009 TE250 (sold)
    I would guess temperature sensor, but it's usually longer than a minute before the bike will start again. Still, might be worth a check.
  3. Moesgaard Husqvarna
    Skaerbaek, Denmark
    TE310 2011
    okay, can I make ohm reading on temp sensor and if, what's the range?
  4. AndrewS Husqvarna
    2009 TE250 (sold)
    You can try just unplugging the temp sensor to see if it makes a difference.
    Regarding the resistance, this is from another thread (found here: http://www.cafehusky.com/threads/coolant-temp-sensor-resistance-values.12267/)
    Hope it helps!
    Did some tests on the Water Temperature Sensor:
    Mine is working correctly and I have no issues.
    I found that with the bike "cold":
    The Resistance between the two prongs of the temp sensor was .690 K Ohms
    The Temp indicated by Ibeat was 28'C or 82.4F
    Which is what the temperature was outside today
    I then started the bike and recorded the Resistance when the fan came on.
    The Resistance between the two prongs was now .162 K Ohms
    The Temperature on Ibeat indicated 207.5'F or 97.5'C
    What this tells you is if you do not have an Ibeat- you can check the Resistance on an Ohm Meter or MultiMeter and see if yours has similar values. I had to go back and forth and there is some delay in doing this so the amounts might be off very slightly.
    Hope this can be found helpful for someone,
    B
  5. Moesgaard Husqvarna
    Skaerbaek, Denmark
    TE310 2011
    Very very helpfull, I will try it out next week, when I get home!
    28'g outside... We are having 9'g windy and raining, unless you like mud racing, scandinavia sucks...
    /P
  6. AndrewS Husqvarna
    2009 TE250 (sold)
    That temperature was in the original post that I quoted.
    It is cold (6c), windy, and rainy here, as well.
    Still, hope to get another ride or two in before the winter!
    Cheers,
    Andrew
  7. BILLF CH Sponsor
    BMP Husqvarna, Salem, OR USA
    92WXC350 /Lamson CR250/701 Vitpilen/
    Triumph900 Scrambler 1200 HD Nightst
    WE JUST FOUGHT THIS ON ONE TXC250 AND IT WAS THE PULSER IT would run fine then miss above 4k then shut off ,cool down do it again.The pulser is only available with the stator so im trying to find a replacement.Try an old analog ohm meter on milivolts scale and see if the trigger pulse is gone whenit quits.think its red & blk wires or red & green.
  8. AndrewS Husqvarna
    2009 TE250 (sold)
    ^ That would make more sense than the temperature sensor, given the relatively short recovery period.
  9. Moesgaard Husqvarna
    Skaerbaek, Denmark
    TE310 2011
    Up and running again, I guess...
    The former owner got a new fuel pump, he also changed the inside fuel lines. But the new lines where not gasolin resistent, so the tank, lines and nozzle where filled with smale rubber part. Tank and lines cleaned, and I got hold of a new noozle. The old one was blue with 10 holes, first owner had a new green 12 hole noozle laying a round in original huske packing.
    I have started the engine up, it revs freely now. But rear frame, shock and swinger is missing (replacing link and swingarm bearings), so havent riden it!
  10. Tetley Husqvarna
    UK
    As soon as I read your first post, I realised that's the same symptoms as I had, and it also turned out to be a blocked injector. See thread.......
    http://www.cafehusky.com/threads/te-450-bogging-and-leaning-out-it-will-only-tick-over-now.36582/
