TE310 2012 runs like garbage the first few seconds
Discussion in '4 Stroke' started by mr_extreme112, Dec 4, 2018.
  1. mr_extreme112 Husqvarna
    TE 310 12
    As you can read in the Title my 310 Runs really bad the first few seconds after a cold start, if you blip the throttle a few times it "clears out". Really hard to discribe. Started happening after i installed the Racing kit with TXC Ecu and 12 Port injector, once the bike warms up it runs flawless. Not directly a problem, but quiet anoying. Has anybody else had this problem? I've reset the TPS and set the CO to 100, as i said once the bike runs fpr a few seconds no complaints.
  2. Oldscool Husqvarna
    South Australia
    None
    RM125, SWM RS500R & Superdual
    Does it seem rich, is there black smoke and a fuel smell?
    If it does then 2 possibles are leaking injector or coolant temp sensor
    Trenchcoat85 and robertaccio like this.
  3. mr_extreme112 Husqvarna
    TE 310 12
    No smoke, just the normal cold-weather condensation until its warmed up.
  4. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    need to do a full fuel system baseline before anything. check sensors, clear all lines, change filter, clean the new injector, dump the tank, etc etc just get the fuel system cleared out and baselined. Then go from there. They are finicky about that fuel system. we are just key punchers here you need to do the elimination trouble shooting, baseline, its not a new bike, valve clearances, compression, ignition system, clean the gen of magnetic debris, etc etc.
  5. mr_extreme112 Husqvarna
    TE 310 12
    What fuel filter do these Bikes use? Cant find it listed in the spare parts catalog. New spark Plug, Valve clearance spot on. How would you clean the injector? Is the coolant temp sensor even a canidate if it runs good after just a few seconds? Pickup is clean, had it open just a few days ago.
  6. R_Little Husqvarna
    NJ
    I use the one from a KTM, "KL97 or something like that.
    It is hard to reuse the fuel lines from the old filter. CA cycleworks sells hose kits and maybe the filter.
