TE310 Fuel pump cycles w/ battery tender
Discussion in '4 Stroke' started by dangslow, May 2, 2013.
  1. dangslow Husqvarna
    St. George, UT
    TR650 Terra and a TE310
    I hooked up my battery tender to my 2013 TE310. I connected the supplied harness to the battery, ran the plug through an opening in the side panel, reinstalled the seat, plugged in the tender and............ITS ALIVE. Then I heard someone say "what the :censored:" Odd, since I was alone in the garage. It seems that the fuel pump will cycle on and off. 1 second on - 1 second off -1 second on - etc. This is the same battery tender I used on my 2011 TE250 and it worked fine. But it had an ignition switch and the 2013 does not. I am playing it safe and disconnected the battery and am using the battery clips to connect the tender. Really not a problem......just strange.
  2. BILLF CH Sponsor
    BMP Husqvarna, Salem, OR USA
    92WXC350 /Lamson CR250/701 Vitpilen/
    Triumph900 Scrambler 1200 HD Nightst
    Ill have to try this tomorrow.
  3. Johnrg Husqvarna
    Santa Barbara
    2013 TE 310 R
    I have mine hooked up as you did. When I connected the tender it would make a click/click every few seconds but stopped soon thereafter as the battery was pretty well charged to begin with. Would be good to know if it's a bad idea on the '13.
  4. R_Little Husqvarna
    NJ
    Bizzare......no way that should happen.
    how can a battery tender energize the pump relay?
  5. LAHuskyrider Husqvarna
    Mobile, AL
    2014 CR144
    1983 Maico 490, 2013 KTM 300 XC-W
    I am experiencing the same issue here. This post is a little old but did anyone ever find out if this is bad for the bike? I would prefer to keep mine on a tender as it can be a few weeks between rides.
  6. Johnrg Husqvarna
    Santa Barbara
    2013 TE 310 R
    I removed mine from the Husky when I installed the earthX battery. Too much switching for me to leave it wired.
