Te350 valve clearance help! Loads of play
Discussion in 'Older Single cams' started by Jimmy604, Mar 3, 2014.
  1. Jimmy604 Husqvarna
    Te350
    After some help please, have searched but can't seem to find the answer...
    I have recently got a 95 TE350 and checked the valve clearances for the fist time and the intake has a massive gap and I can lift it up about 5mm, I have tried to wind down the adjuster but it seems to be getting stuck on the thread somewhere and not going down that far (on both)
    Has anyone come across this before?
  2. HardCoreHusky Husqvarna
    South Carolina
    1991 350WXE, 2004 TC450
    01 Royal Enfield Bullet, 91 KTM 250
    Have you got it sorted? I'm relatively new to my 91 350, already checked my valves and clearances were spot on. The amount of clearance you've got is not right for any engine. How does the cam lobe look? The rocker arm contact pads? Threads for the adjuster or on the rocker may be bad?
  3. Up-tite Husqvarna
    Sounds more like not at TDC compression stroke.
    Later George
