TE449-511 Key Switch
Discussion in '4 Stroke' started by Waverider, Jan 4, 2013.
  1. Waverider Husqvarna
    Kaneohe, Oahu
    TE 449
  2. drdfblackm Husqvarna
    Flagstaff AZ
    Indeed...and will it work on a TXC511 too???
  3. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Cheaper than the stock one if you don't mind not having matching keys for the fork lock. You can put any key into the stock ignition spot, but you can only get the lock ring that fits from Husky. Might be a good alternative if you don't wish to splice the original part into the harness. :)
    http://www.cafehusky.com/threads/key-switch-for-2012-449-511.26785/
  4. Bryce Husqvarna
    Denver, Colorado
    2012 TE511
    Honda ST1300
    I just ordered one and will tell you how it goes. Great find Waverider!
  5. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    2011-12 Husky TE449-511 Clutch Interlock Bypass $5.00
    - Pretty cool. I ordered one. :)
  6. Waverider Husqvarna
    Kaneohe, Oahu
    TE 449
    Right on Bryce and Tinken! Bryce, I am looking forward to hearing from you.
    Aloha
  7. HusqRacr Husqvarna
    Escondido, CA
    TE511, 10' WR300, 2015 FC450
    Ducati 998, KTM 520EXC
    Just got mine in today. Quick install, probably took 10 minutes and works great! I like the fact the key is the ATV style to keep the elements out. Makes me a "little" less worried parking it somewhere in town. I can post pics if anyone would like them. pretty straightforward install.
    Aaron727 likes this.
  8. 310huskyTE Husqvarna
    Melbourne Australia
    2014 FE 350, 2011 Meo.
    67 CR250, 71 400 Cross, 78 CR250
  9. Caiman Senior Vice Procrastinator
    Australia
    SWM SM500R
    The 2013 (and maybe 2012) aussie delivered bikes have an hydraulic pressure switch on the clutch, whereas the '11's don't Saw it at the dealers and wondered wtf it was, also noticed they've changed the reservoir lid on the '13's to mention DOT 5.1 fluid compatibility,
  10. 310huskyTE Husqvarna
    Melbourne Australia
    Wow, must be new on the 13's but i really can't comment on the '13's as i haven't owned one yet, but my 12 310 didn't come with a pressure switch on the clutch.
    Now that i think about it before i rode Huskys i had a Yamaha wr250f that you had to pull the clutch in to start it, but that could be by passed by cutting the cable to the switch and joining the two wires together
  11. Bryce Husqvarna
    Denver, Colorado
    2012 TE511
    Honda ST1300
    Installed the key switch yesterday. Easy and straightforward. Rode ~40 miles yesterday and it works great!
  12. Waverider Husqvarna
    Kaneohe, Oahu
    TE 449
    Thanks Bryce, ordeing mine today!
  13. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    What functions does it give you? Does it turn the comp on and off?
  14. Bryce Husqvarna
    Denver, Colorado
    2012 TE511
    Honda ST1300
    It disengages the starter button. So when the key is off and you hit the starter it does nothing. You turn the key on and you still have to hit the starter to get the dash to come up and the pump to prime. If you turn the key off while it is running it will shut off and the dash will stay on for a bit just like when you hit the kill button.
  15. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Okay, so it just goes inline with the wiring to the starter and kill button then, cool, that's an easy fix. Mine is basically wired like that now. Since I had mine installed, Wayne Martin @ Malcolm Smith's has installed a Husky key ignition that turns the computer on, the efi, the pilot light headlight as well as an efi reset. I'm not sure what is involved in all that but I am going to feed 12v through my ignition to run a secondary computer and other accessories.
  16. Rainer Husqvarna
    2012 TE511
    2012 Super Tenere
    I did install that Switch also. Straight forward Plug and Play.
  17. James Patton Husqvarna
    Edwardsville, ILL
    TE511 2012, WR125 2006
    1250S Bandit, DRZ400S
    I should have mine this coming week. Should be here Monday/ Tuesday. I would like that false sense of
    security too.
  18. Lancaster Husqvarna
    Lakes Entrance, Victoria
    TE 510
    Could you guys post some pics of the ignition install? Please!
  19. Badf250 Husqvarna
    Pittsburgh PA
    Te 449
    Suzuki Sv650, Yamaha DT125
    I'm very interested in this. Does it fit in the stock location?
  20. Bryce Husqvarna
    Denver, Colorado
    2012 TE511
    Honda ST1300
    Yes, it does. It comes with instructions and is very easy to install. Just drill out the cap in the stock location, and plug it in. Lancaster, there is really nothing to the install. Very straight forward. As for pictures, the finished product looks just like a 2011 with a stock keyed ignition.
