Te450 2009 Shock Seals Part Number
Discussion in '4 Stroke' started by xkam555, Sep 14, 2023.
  1. xkam555 Husqvarna
    TE 450 2009
    CBR600RR 2005
    Can anyone provide me with all balls part number for rear shock seals for TE450 from 2009 (Sachs shock)? I’ve found whole seal unit (37-1124 probably), but I’m looking for seals only.
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Good luck with that. I had to fix a leaking shock on my 2007 TE450, and getting the separate seals proved to be too difficult to source, while the OEM kit was too expensive. I ended up getting an inexpensive All Balls seals head and modifying the shock so that it would work. This included removing some of the old parts and installing spacers to get the proper build length.
  3. xkam555 Husqvarna
    TE 450 2009
    CBR600RR 2005
    Do you remember all balls part number? On the first pic the part you’re holding is all balla, while on shock part is original? You’ve removed spring and installed spacers in that place? It seems that 2009 shock is a bit different, also I’ve seen post that 2007 has 16mm rod, while 2009 probably has 18mm - I’ll measure that later.
  4. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    Top pic is stock, bottom pic is AllBalls. Removed top out spring, shaft C clip, chamfered C clip groove in shaft, got teflon flow through spacers from Racetech. Can't remember part number. Here is sizing chart from allBalls. If you have technical questions, talk to somebody at the company phone number.
