TE450 2010 starting issues
Discussion in '4 Stroke' started by gestion01, May 3, 2010.
  1. gestion01 Husqvarna
    Montreal
    I have a friend with a brand new 2010 TE450 and it will not start. Trying to find a solution for him before he quits and goes to another color. Husky as been of little help other than saying it needs to break in.
    I've owned a 2008 TC450 carb version and with the proper jetting it started better than my wr125.
    Any ideas on proper setup for the TE?
  2. cbreakin Husqvarna
    SoCal
    2009 TE510
    What symptoms is it displaying? Is cranking over? Is the fuel pump priming? Is he using the "choke" when cold? How many miles, is it "powered up"?
  3. BILLF CH Sponsor
    BMP Husqvarna, Salem, OR USA
    92WXC350 /Lamson CR250/701 Vitpilen/
    Triumph900 Scrambler 1200 HD Nightst
    We had a couple doing this.We learned give it full throtte while cranking and let it snap closed and both bikes would start every time just as it closed all the way.Then as they got more time on them it got better ?Worked for us.>only 2010 Te450,09 perfect / give it a try.billf
  4. gestion01 Husqvarna
    Montreal
    E-start will not get it going. And kick start until your dead. And yes it is uncorked. Sensor plugged or not does not change anything. Brand spanking new..under 160km.
    I don't fully understand the ''let it snap closed part'' ...
  5. Ex HVUK Husqvarna
    England
    None
    I always recommend the following:
    Fast idle pulled out
    Clutch pulled in
    Press starter button with finger to avoid opening throttle at all when starting
    Assuming the battery is sufficiently charged this technique always works for me.
    Dave
  6. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    Estart turns over though right?
    turn key to ON,
    Kill Switch: red button out-
    (should hear fuel pump - prime system)
    Pull out fast idle (choke)
    pull in clutch (if safety switch is still connected)
    don't touch throttle
    Hit black starter button....
    If the pump is priming and the starter turns the motor but it is just not firing:
    -does it have spark?
    -does it have gas?
    -1 thing to check is the coolant temp sensor- in front of the throttle body on the back of the head on the left hand side near the head pipe: disconect the wire connector and try to start- if it starts after all that with it disconected- replace it.
    If none of this works- have it hooked up to Ibeat
  7. gestion01 Husqvarna
    Montreal
    Ok we have something to go with now try it all out. Thanks
    Apparently the 09's don't have this problem... and this is an 2010. I think
    BILLF maybe on to something. Full throttle and let it snap back...hey whatever works :thumbsup:
    will post back results.
  8. audible Husqvarna
    Temecula
    2007 TE450
    • red button out
    • fuel on
    • choke out
    • neutral
    • pull clutch in
    • 2 full throttle twists and release
    • push start
    • ===> starts right up.:applause:
    Now upon stalling it and causing vapor lock...:banghead: I have had to pull the Decomp-lever, cycle it, she'll fire. Note from experience...do not kick start these bikes without boots on :eek:
  9. bbcmat Husqvarna
    ontario
    Get Ross Rocher Sales on the phone and he'll fix you right up.
    Be prepared to LISTEN to what the mechanic tells you.
    MAT
  10. ScottyR Husqvarna
    Mitchell, ON
    Mat, you are the resident EFI expert. I wish I could afford to have you work with me. :cheers:
  11. bbcmat Husqvarna
    ontario
    I would really enjoy getting together with you guys - but there is no time to take something like that on.
    The PDI prep on my bike was excellent - alot of skill and experience there.
    MAT
