TE510 2009 - Magura master cylinder oil leak
Discussion in '4 Stroke' started by tamb, May 2, 2024.
  1. tamb Husqvarna
    Hi all,
    I have an oil leak from the master cylinder in my TE, the pump is a Magura.
    I assume is needed to change the OR kit or to made a rebuild of the internal assembly, would anyone be able to tell me if there is a kit to do that?
    I don't know what is the model of the pump, but it is identical to the attachment.
    Thanks
    T.
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Double check the black rubber top seal just under the lid. Sometimes those get a bit mis-shaped and will allow fluid to escape. You can sometimes carefully realign them to the groove they are supposed to follow and stem the leak.
  3. kirbybikes Husqvarna
  4. Ghostman Husqvarna
    Portugal
    TE 450
    Brutale 990, Vespa GT200
    Angsty likes this.
