Hello together, since one week i'm hearing during the ride a knocking from inside the engine with a speed dependet buzz. Yesterday it get so loud, that i stop the engine, because I was afraid something goes damage. It sounds like a knock from the camshaft. This video i made last week. It was quiter at this moment, than today. Because i don't know enough about the bearing tolerances, i made some videos of the parts an would be very happy, if we finde the technical problem by this way together. AutoDeko at Camshaft Is it right, that the sping is very powerless like in the following video? Or could cause this the beat? Rocker arm clearance - defective bearing? Camshaft bearing - Too much clearance? Thanks a lot for your Help
I would replace the bearings of the camshaft. The spring of the auto deco doesn't look too weak to me and even if it was too weak, it could cause problems when starting the engine, but it shouldn't affect what happens later, as far as I know.
Hi together, ok, i have ordered some new spare parts for this bike. And so on i think, i have finde the reason for the knocking engine... That's the the back chain slide. It Look's destroyed in my eyes ^^. Thus i ordered the following parts: - Back chain slide - Rocker arm bearings - Head gasket - Waterpump seal - Waterpump bearing - Camshaft bearings ... i hope, the replacing of this spare parts will be the solution for the knocking eninge
