TE610 and Eastern Beaver
Discussion in '610/630' started by sumbike, Feb 1, 2015.
  1. sumbike Husqvarna
    Rancho Murieta, CA
    TE610
    KLR 650 Sold
    Added heated grips to my 2008 TE 610 and decided the wiring at the battery was becoming a mess with the battery charger, GPS and now grips wires all connected to the terminals. Ordered and received a 3 circuit harness from Eastern Beaver to clean things up. Can't say it looks cleaned up, but, it is much better organized. Ran flex conduit for the wires from the battery to the front behind the light.
    Eastern Beaver harness
    The EB harness is nicely made and the water proof 3 circuit fuse box a nice consolidation of the fuses in one place.
    maxyb likes this.
  2. Coop610 Husqvarna
    Acme Pa
    2006 TE610
    1982 Suzuki PE 175
    Looks good.
    I just built a 3 circuit harness for my wife's XT250 and once the tamper proof allen tools come in and I can pull the plate off the Britannia fairing so I can see how the previous owner wired the USB and power outlet, I will probably make one for my 610 as well.
    This is the one I built (before hooking up and why the blue wire is left so long, I wasn't sure how far it was to switched 12v power for the relay. I used sealed connectors so it is completely watertight.
  3. sumbike Husqvarna
    Rancho Murieta, CA
    TE610
    KLR 650 Sold
    Nice work!
    I plugged in to the "parking" light behind the headlight to activate the relay for the heated grips only when the key is on. The relay is mounted to the underside of the bracket that supports the instrument display.
  4. Coop610 Husqvarna
    Acme Pa
    2006 TE610
    1982 Suzuki PE 175
    Thanks. The only reason I didn't get the Eastern Beaver kit is because I had half of the parts already. EB builds some great quality stuff.
  5. sumbike Husqvarna
    Rancho Murieta, CA
    TE610
    KLR 650 Sold
    I would have done the same if I had the stuff. After checking around at several local auto parts places and on line, the EB kit made sense. I didn't have anything to start with.
    Coop610 likes this.
