I just received my clutch cable from Motosportz (thanks for the fast shipping guys). I have heard that with some newer cables, the lining of the sheath is a special material (teflon maybe) that can be damaged by using cable lubricant. Can anyone tell me if it is okay/advisable to lube the Motosportz TE610 clutch cable? Thanks, Andy
The cable is motion pro terminator cable, follow the instructions for terminator cables and you will be ok.
Best cable lube is Marvel Mistery Oil. Unhook cable from both ends use the dust cup as a funnel, pour it in when it starts to run out bottom of cable twist the cable and work the cable this will flush out dirt and grunge. Spray lubes just crud it up. Later George
