TE630 Fuel.
Discussion in '610/630' started by 128954431, Sep 3, 2010.
  1. 128954431 Husqvarna
    NT, Australia
    Where is the :duck: emoticon?
    Fuel Octane: I notice that the service manual specifies "98 Octane" for this bike. I assume this is RON. Problem is that the best I can normally hope for is 95RON or less... Hurrah for octane boosters.
    Question is what are peoples experiences as far as the minimum fuel octane (without a booster) in these bikes? Also, what mods (eg exhaust, EGO removal) are associated with those experiences?
  2. organ donor Husqvarna
    Berlin
    I can get extra premium here. Don´t intend to use anything with ethanol in my 630 (pu kit and sensor disconnected). I once ruined a small Continental 65 aircraft engine using bio-MOGAS. Never again!
  3. 128954431 Husqvarna
    NT, Australia
    Thanks for the reply. What I am looking for is experiences with minimum fuel octane. ie What is the lowest grade of fuel people have run for an extended period without melting their engine?
    Fortunately ethanol fuels are very rare out my way.
  4. Tagati Husqvarna
    NQ Australia
    I just put the highest RON fuel they have in it. Have run it on 91 for a tank and couldn't really tell the difference (Maybe a bit of bottom end surging, but my bike spends bugger all time in the bottom end). You take what you have to take :excuseme:
  5. organ donor Husqvarna
    Berlin
    Agree! Just don´t EVER use anything with bio in its name :thumbsdown:
  6. 128954431 Husqvarna
    NT, Australia
    Thank you. That is the sort of thing I am after. Was the bike stock or running the PU modification?
    Anyone else had similar or bad experiences with 91RON or the US grade 87AKI?
    EDIT: Well, I think 91RON = 87AKI. Standard grades in the US are 87, 89, 91?
  7. Tagati Husqvarna
    NQ Australia
    Stock. Australian 630's come set up to run in full power mode with the o2 sensor in place. So there is no point in putting in a PU kit in an aussie 630.
    We don't have cat's in our can's either :thumbsup:
  8. ghte Husqvarna
    Bright, Victoria Australia
    I really think 95 is OK for the 630. I have used it in my 510 and 450 in the past and no difference what so ever.
  9. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    Here, they have 87, 89 w/10% Ethanol, and 91 octanes. It's probably a different scale than you folks use. I have run the 87 and 91 without problems. I avoid the Ethanol blends.
  10. 128954431 Husqvarna
    NT, Australia
    Sorry, forgot you're in Oz. The question is more relevant to the US riders. Mixture enrichment of the PU mod will make a difference to anti-knock.
    It pleases me that we don't have to go through the hassle (I reckon it is small) of our US cousins to get these bikes to run... while maintaining the benefit of the EGO sensor or is that missing too?
    One of the things that concerned me about the PU mod dropping the computer onto the base map without EGO closed loop support and hurting fuel consumption cruising at low to moderate loads.
    This brings me to another question. What sort of fuel consumption do you guys get from the 630 steady state at say 110kph/70mph on the highway? Assuming that you can keep the right hand under control.
  11. organ donor Husqvarna
    Berlin
    I didn´t buy it (630SM) to save on fuel. It uses approx. 7 litres/100kms. And it´s no use ... I can´t keep my right hand under control. That´s why I bought it (sensor disconnected pu kit and Arrow zorst)
  12. Tagati Husqvarna
    NQ Australia
    :excuseme: No idea about hwy fuel consumption. I can tell you that I use 5l per 100km on muddy dirt roads with a bit of hwy. But that will change as the bike breaks in. And that wasn't riding steady. I recon you can count on 230km from a tank.
  13. kevinperry Husqvarna
    Ontario
    2011 TE 630
    1982 honda XL250R
    Driving somewhat sane .. 200-230k's on 10L before the reserve lights comes . Hammer hard ....as little as 180k's, still great for a 600cc thumper!
    KP
  14. 128954431 Husqvarna
    NT, Australia
    Thanks guys. I had a look around and 22-26km/l seems to be the range of numbers for highway riding at sane speeds. Constant highway speeds are usually a fairly good indicator of how frugal a bike can be. Hard ridden off road or just hard conditions can be even more telling.
    OD, fuel consumption matters when living in an area the size of Germany with only a handful of places to get fuel. There are a lot of places where 700km in hard conditions with a safety margin is required. Any increase in consumption needs to be proportionally offset by an increase in tank capacity... and weight carried. Add a couple of days of water and the weight starts to add up very quickly.
    Even your numbers are of value because they demonstrate what the bike is capable of when ridden hard. Of course I'll have my own numbers before getting into anything heavy. I just wanted an idea.
  15. Busted RS Husqvarna
    Perth, Western Australia
    2011 TE630, WR300 '09
    DT360A's
    Aussie 630's
    Can you expand on that about Aussie 630's being in "full power mode" with the 02 sensor installed ? Can you tell us what and from who, have you been advised about that ? :confused:
    Also, some time ago I mentioned my dealer advised Aus 630's did not have Cats fitted. (this was before delivery) Later he corrected to it being a different type of cat to what the 610 had. (I believe now the 630 cats are deep inside the 2 cans and would require surgery to remove).
  16. organ donor Husqvarna
    Berlin
    Correct! You can´t really see it in the pic .... but it´s right down inside there. And I can´t see any way of getting it out without causing damage. Couldn´t find a cat in the twin Arrows though.
  17. Tagati Husqvarna
    NQ Australia
    My dealer gave me a print out from the importer. No cat's and full power mode out the box. There is also revision for a de-tuned version in the future (cam on the throttle) I have to admit mine is about the loudest stock bike I have ever owned. :thumbsup:
    http://www.youtube.com/watch?v=QR87GLVhPEU
    I suppose one way to check would be after work I could post any numbers on the cam's.
  18. 128954431 Husqvarna
    NT, Australia
    I'd expect a different ignition/fuel map to the US and EU with our loose emissions requirements on bikes... if they are different.
    There is also a version of the bike on the lams list. By my reckoning it would have to be detuned slightly.
  19. Tagati Husqvarna
    NQ Australia
    Ill scan the print out have
  20. 128954431 Husqvarna
    NT, Australia
    I don't doubt your word.
    It would be interesting to know exactly what is different.
