smooman
2011 TE630 (700km's on the odo):
I started a log of my initial JD settings and then went riding (on my own personal test track
Initial settings:
Elevation (according to GPS) is between 50-80 metres ASL, and todays temp is 22 C.
So, what did I find?
The Arrows ECU is waaaaay rich.
Removing the Arrows cans was a bit of a giveaway, they were soooty black like an old diesel exhaust.
The recordings with these settings, all in 5th/6th gear, showed AFR's down in the low to mid 11's.
I ended up with:
More time needs to be spent (low on fuel) as still working out the way the JD tuner transitions from yellow to red, I get a nice low 13 on yellow as it climbs the LED's up to 7 but then as 8 lights up green it drops to mid 12's.
A big thumbs up for the tunability of the JD though, any 1/2 step increments are clearly visible in AFR results.
I wonder if I should pop the stock ECU back in and work out settings for it?
Could be of some help to others in Oz with similar setups, temp/elevation, and fuel.
- Power up.
- Arrows ECU, removed the exhaust (too purdy...)
- FMF 4.1 factory system installed.
- 98 RON.
- Opened up airbox. (removed snorkel, drilled extra holes around the throttle body intake).
- JD tuner (taken from the 2008 510).
- TPS was originally set by dealer (I'm told), I have not checked it and should get iBeat to make sure.....
).Initial settings:
- G - 3
- Y - 5
- R - 6
- GB - 3
- YB - 4
- RB - 6
I ended up with:
- G - 1.5
- Y - 1.5
- R - 2.
- GB - 1
- YB - 2.
- RB - 2.5
