Terra Exhaust-ectomy
Discussion in 'TR650' started by Kevin Churchill, Apr 14, 2013.
  1. Kevin Churchill Husqvarna
    te 650
    BMW R1200 GSA , Yamaha WR250R
    I am a old guy. One of reasons I got a Terra was so I could pick it up by myself.
    Weight is an issue on all D/S bikes.
    So WHY oh WHY does the Terra (as well as the BMW F650) have two exhausts.
    Looks like a styling thing.
    The could drop 15-20 lbs by getting rid of the left hand exhaust.
    This could done by cutting and welding a plate over the Siamese where the two pipes connect.
    The pipe diameter is large enough for a 650.
    The question:
    Has anybody contemplated this operation.
    I am contemplating removing the right hand pipe, inserting a plug as far I can get it down the stub, and having the bike dynoed (before and after) to see what the issues (if any) arise.
    I am surprised that this simple (and very significant) weight reduction hasn't been tried before.
    Please chime in with any possible issues.... back pressure, mixture etc.
    Would not the FI automatically make some adjustments?
    I know this would invalidate the balance of my warranty.
    Thanks in advance for any suggestions.
    Kevin
    Luge likes this.
  2. blaine.hale Husqvarna
    2013 Terra TR650
    1973 BMW r75, 1974 BMW R90, Bultaco
  3. Ryguy Husqvarna
    Escondido California
    650 terra
    Do it, I'm curious
  4. spiderman Husqvarna
    Decatur, IL
    07 KLR650 07 Bandit1250 85 Rokon
    I've been waiting for someone to jump on this. Good luck.
  5. kjackbrown Keep on keepin on.
    Fresno, Ca.
    KLR650
    x2...and if your going to dyno it anyways...May as well put a power commander on and tune it for the pipe
    HuskyDude likes this.
  6. RidingDonkeys Husqvarna
    Paso Robles, CA
    TR650
    Yep, I think many of us have been wondering about this, but with it being a new bike, nobody has taken the plunge.
  7. kjackbrown Keep on keepin on.
    Fresno, Ca.
    KLR650
    Late last year I contacted a bunch of aftermarket pipe makers and they all pretty much said that they may interested in making something later on in the year (too many projects already in the works). Just gotta keep calling them back and see if/when they are ready.
  8. Motosportz CH Sponsor
    For me the bike is somewhat heavy anyways and I like the quiet stock cans and the bike makes good power. Your idea is very sound and should do what your after but the stock stuff works fine with me as is.
  9. mario33 Husqvarna
    Warsaw, Poland
    AFAIK, stock ehausts with header pipes are 13,5 kg = 28 lbs (read it somewhere, confirmation needed).
    I'd rather wait for proper aftermarket street-legal 2-in-1 (that is absolutely necessary for EU). Should be roughly ~18 lbs save and with better power/noise ratio.
    Still happy to see whats the final effect.
  10. blakebird Husqvarna
    Parker, CO
    '16 FE501S
    '14 Super Tenere
    I think it's as much for exhaust volume as anything - most big thumpers have one huge muffler, the Terra and TE 630 get two much smaller ones.
    I put the expensive Leo Vince single exhaust on my TE 630, but it turned out to not be compatible with the Uptite Racing skidplate, so I sold the single Ti exhaust and got their aluminum dual setup....which I ended up liking the mellower exhaust note of.
    There's a bit of weight to be saved, but it's not going to make a gigantic difference on a 400+ lb bike.
    Motosportz likes this.
  11. spiderman Husqvarna
    Decatur, IL
    I'm more interested in removing the exhaust from one side so I can mount an auxiliary fuel cell there instead. I'd like to make it look like the original exhaust if possible.
  12. Allen Husqvarna
    NYC
    Honda NH750
    I think if there was a single exhaust that wasn't obnoxious available for the bike I would be interested. I think the weight savings ARE huge! Where else could you cut off 20 lbs from the bike and free up some space for a fuel can / tool tube.
  13. Kenneth Webb Livin' It Up!
    Tucson AZ
    TE630 TR650 Terra TE310R
    A single exhaust and a Shorai on my TE630 was worth a smooth 20 pounds and small change. That's a LOT and maybe the only way to pare down the Terra. There is a massive amount of steel in the frame; nothing to be done about that. I suppose someone could go crazy and make up an aluminum swing arm for a few more pounds.
    I will wait for one of the major aftermarket exhaust folks to make up something for the Terra but whether they build a can, or you do it yourself, the bike will need to be tuned after the change. I don't think you can do that without something like the JD Tuner or Power Commander V, so plan on more bucks out the door. If you plan to keep the Terra long term though, the money will be well spent.
    Now, I'm still thinking about what can be done to the timing to let regular gas be used when needed. Any reports or experiences along those lines?
  14. RidingDonkeys Husqvarna
    Paso Robles, CA
    TR650
    Well, if it is any consolation, every gas station I stopped at over my first 600 miles only had regular fuel. I couldn't tell a difference. :confused:
  15. Motosportz CH Sponsor
    My feeling as well. Until there are EFI mapping and richening parts out there modding the exhaust for performance will be hard.
  16. Kenneth Webb Livin' It Up!
    Tucson AZ
    And.... keep in mind that at full throttle the EFI is working to full capacity. No room for growth there.
    What I had in mind by my comment on regular has to do with folks who wander far afield in less developed countries, like Mexico and everything south of there. My buddy Kevin is headed to Tierra Del Fuego and I doubt there is a lot of high test along the way. That probably applies to the route to the Arctic as well, but I don't know that for sure. Kevin's Terra is about to get the ultimate smoke test!
  17. mario33 Husqvarna
    Warsaw, Poland
    THAT would be the ultimate mod for the Terra. Might be costly though me thinks - but still interesting idea :thumbsup:
  18. Hansi Husqvarna
    State of Jefferson
    TR 650
    09 Versys
    I have been using regular and/or premium from mile one in my Terra. I don't think I can feel or hear a difference. No pinging or lack of power with regular. Maybe that will change when the weather is getting hotter? Maybe the boosterplug that I have installed makes a difference?
    My dealer Bill from BMP in Salem, OR told me not to worry about the grade of fuel to much. Would be nice to get more feedback from other members of this forum on that issue.
  19. RidingDonkeys Husqvarna
    Paso Robles, CA
    TR650
    This is my first fuel injected bike. Also my first liquid cooled bike. (I'm old school) So take this with a grain of salt.
    On my carbd and air cooled bikes, I'll run regular Fall-Spring, and run premium in the Summer. Higher octane will burn at a lower temperature, hence using it in summer. I've run a few tanks of both in the TR, and never noticed a difference. Switched from premium to regular midway through a 190mi ride and still didn't notice a difference. Given the liquid cooling, we'll see how things go this Summer, but I continue to not notice the difference, I'll save a few bucks.
    What I'm more interested in is how it handles ethanol enriched fuel. That crap sucks!
    PaulC likes this.
  20. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    :lol:
    I'm right there in that tiny little fish bowl with ya....
    I'll run High Octane when possible and if I'm on a long trip and can't find any, regular will do...not gonna sweat it over that.
    :cheers:
