RidingDonkeys
So you want a Terra and can't find one. Or, you want a Terra with ABS, and it isn't sold in the US. Or, you've found a Strada cheaper than a Terra, and now you are confused. Either way, there is a solution. There has been a lot of talk about this for a while, so I figured it deserved a dedicated thread. This is the how-to on creating your own Terra-fied Strada.
You start with this, a stock Strada. First, you remove the decals, because they suck.
The Terra and the Strada are the same bike underneath. Outside of the ABS, everything else is bolt on. So you'll need to order a series of parts. I will update this list with part numbers once I get it all sorted out. A few of the part numbers we used were incorrect, and had to be rectified. I don't want anyone else to make the same mistake. Even when I get them up, please verify them before ordering.
21" Spoke Wheel Assembly
21" Front Tube and Tire
17"/18" Spoke Wheel Assembly (Both are available. I went 17" for tire selection)
17"/18" Rear tube and tire
High front fender
Fork guard assemblies
And that is all you really need. This is assuming you'll be recycling your brake discs onto the new spoke wheels. If you want a true convertible bike, you'll need to order a spare set of discs and ABS sensor rings. However, bolting the discs up only takes a few minutes, and most people aren't likely switch wheels frequently, if ever at all.
You could skip the fork guard assemblies, but they hold the cables in place, as seen below. Zip ties work too, but the guards are only $7. This was an oversight, and my guards are now on order. I'm currently using the zip tie method. This is what right looks like, on a Terra.
When it is all said and done, you'll end up with something like this.
Now you'll probably want to add some accessories. The Strada is compatible with almost everything that you can get for the Terra. In the photos, I have SW-Motech crash bars and skid plate attached with no issues. There is one notable exception to compatibility: handguards. I prefer Barkbusters. They are strong and aerodynamically stable at speed. However, the ABS system gets in the way of a Barkbuster install. It fits, but barely, and in the event of a crash, the mount could take out your brakes if it flexed. My work around was a mount from Moose Racing that is designed to go under cable assemblies.
This is the part number:
And here it is mounted.
So that is a Terra-fied Strada in a nutshell. I welcome input from anyone else. There are many ways to skin a cat, and this is just the way I chose. So post up what you've done to your Strada!
High front fender
